Adding sizes of polygon to layer
1256
09-12-2012 05:11 AM
AndrewIosida
Hello!
1. Is it possible to calculate length of every edge of polygon?
2. And add results to layer near each side of polygon?
I calculating length of sides now by GeometryService.distance(params);
In distance() I send two points on opposite sides of the edge of polygon. It works very well but I have problems with adding label with length to correct side of polygon. I just thought that exists function that makes it all (placing sizes of polygon on map in the right place).
Thanks in advance. And sorry for my bad english.
AnthonyGiles
Honored Contributor
Andrew,
This widget does a similar function to what you want to do, you may get some ideas from the code:
http://www.arcgis.com/home/item.html?id=36a80475e5d740279854398d3f7b6d01
Regards
Anthony
AnthonyGiles
Honored Contributor
Andrew,
Regards
Anthony
AndrewIosida
Anthony,
Thank You very much for your help! In this code I found all that I need.
With best regards, Andrew.
