Add a graphicsLayers
1217
09-15-2011 05:45 PM
ShaunWeston
This is probably a simple answer, but for some reason I just can't get a graphics layer to add when I click on a map. THe alert "map clicked" does come up, but the point graphic layer is not added to the map?
   private var myGraphicsLayer:GraphicsLayer = new GraphicsLayer();
   private var configFeatureLayers:Array;
   //this function called when the widget's configuration is loaded
   private function basewidget_widgetConfigLoadedHandler(event:Event):void
    if (map.loaded)
     Alert.show("map loaded");
     loadHandler(null);
    else
     map.addEventListener(MapEvent.LOAD, loadHandler);
    function loadHandler(event:MapEvent):void
     map.removeEventListener(MapEvent.LOAD, loadHandler);
     map.addEventListener(MapMouseEvent.MAP_CLICK, clickHandler);
    function clickHandler(event:MapMouseEvent):void
     showPopup(event.mapPoint);
    function showPopup(mapPoint:MapPoint):void
     Alert.show("map clicked");
     myGraphicsLayer.clear();
     var graphic:Graphic = new Graphic(mapPoint, clickPtSym);
     myGraphicsLayer.add(graphic);
IvanBespalov
<viewer:BaseWidget ...>
private var myGraphicsLayer:GraphicsLayer;
 * Listen widget template open handler
protected function openHandler(event:Event):void
    myGraphicsLayer = getMyGraphicsLayer();
    if (!myGraphicsLayer)
        // show alert 'Graphics Layer is null'
 trace("GraphicsLayer not found");
    else
        trace(StringUtil.substitute("GraphicsLayer with id={0} found", myGraphicsLayer.id));
 * Get existing graphics layer or add new if does not exists
private function getMyGraphicsLayer():GraphicsLayer
    var result:GraphicsLayer = null;
    if (map)
        var mapLayers:ArrayCollection = map.layers as ArrayCollection;
        for each (var mapLayer:Layer in mapLayers)
     if (mapLayer is GraphicsLayer)
         result = mapLayer as GraphicsLayer;
  map.addEventListener(MapMouseEvent.MAP_MOUSE_DOWN, onMapClick);
  break;
        // if map has not any graphics layer add new
 if (!result)
     result = new GraphicsLayer();
     map.addLayer(result);
    return result;
 * Listen map mouse down event handler
protected function onMapClick(event:MapMouseEvent):void
    if (myGraphicsLayer)
        var grGeometry:MapPoint = event.mapPoint;
 var sms:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, 0xFF0000);
        var attributes:Object = new Object();
 attributes.dateadded = new Date();
 var gr:Graphic = new Graphic(grGeometry, sms, attributes);
 var grId:String = myGraphicsLayer.add(gr);
 trace(StringUtil.substitute("Graphic with id: {0} added.", grId));
 * Listen widget template close handler
private function closedHandler(event:Event):void
    if (map)
        map.removeEventListener(MapMouseEvent.MAP_MOUSE_DOWN, onMapClick);
<viewer:WidgetTemplate id="wTemplate"
      width="300"
      height="300"
       closed="closedHandler(event)"
      open="openHandler(event)">
<!-- Here are widget contents -->
 </viewer:WidgetTemplate>
</viewer:BaseWidget>
ShaunWeston
Oh yeah thanks,
I managed to fix it and get it working, I'm not sure exactly what the problem was.
