Web App Builder Developer Edition, is jQuery a supported language?
10326
04-02-2015 01:13 PM
CenterlineMapping
In Web App Builder Developer Edition, is it possible to use jQuery to develop custom widgets, and if so, which file within the custom widget folder would we add the jQuery script tags to?  Here is the jQuery CDN libraries we would like to reference.. //code.jquery.com/jquery-1.11.2.min.js
GuthierryAlmeida
It's possible. In your "Widget.js" file use the "jimu/loaderplugins/jquery-loader":
define(['dojo/_base/declare', 'jimu/BaseWidget', 'jimu/loaderplugins/jquery-loader!https://code.jquery.com/jquery-1.11.2.min.js'],
function(declare, BaseWidget, $) {
     return declare(BaseWidget, {
CenterlineMapping
Thank you, I was not aware of this solution.
I found another solution by adding the jquery script tag into the application index.html page.
diaconori
Does this still work? Can't seem to make it work with 3.37
diaconori
confirmed. Does work very nicely. Used it for some auto completion for one of our widgets.
