arcPro 2.5 update cannot connect to sde
2582
02-07-2020 08:51 AM
ZachLampert
I ran the 2.5 update this morning but am now getting "Error, Connection was attempted with an older version of SQL Server client communications software that is not supported."
We run 2012 R2, and had absolutely no issues connecting to sde in 2.4 and earlier. Is this a known issue? Is there a fix?
MarcoBoeringa
AndrewSouthern
Having this issue as well.  Can connect to same database via Arc Catalog 10.7.1 but not in ArcGIS Pro 2.5.  Using SQL client 2012.
MarcoBoeringa
AndrewSouthern
Thank you this helped.
