Logitech MX Master horizontal scroll wheel for attribute table in ArcGIS Pro
9628
7
08-31-2020 08:55 AM
DerekMcGovern
Hello
I am running ArcGIS Pro 2.5. I routinely work with attribute tables that are many columns wide and have a Logitech MX Master mouse that has a horizontal scroll wheel on it. I have the Logitech Options installed on Windows 10.
It appears ArcGIS Pro is the only app where the horizontal scroll wheel does not work as intended? Is there a fix for this?
dzahsh
I have a MX Master mouse as well and have not found a solution for using the second scroll wheel, but for those who are not aware holding Shift and using the primary mouse wheel works in ArcGIS Pro to scroll horizontally in attribute tables
DerekMcGovern
I was not aware of this. Thank you so much this is info is really helpful.
tiztrain
Good to know thanks!
BrandenHarding
I've found another workaround too if you're using MX Master Mouse. In Logitech Options, change the horizontal thumbwheel to do keystroke actions. Turn up = right, Turn down = Left. I set this for ArcGIS Pro specifically. After some tweaking of sensitivity, this seems to work quite well.
DerekMcGovern
Thank you I will give this a try. I was originally thinking to program the Shift + vertical scroll to the horizontal scroll. But this sounds like it'll work too.
tiztrain
@DerekMcGovern Did you ever figure out how to program/assign it to 'Shift + vertical' scroll?
KoryKramer
Esri Community Moderator
Anybody looking for this functionality, please go to this idea that was submitted and add your Kudos there https://community.esri.com/t5/arcgis-pro-ideas/logitech-mx-master-sideways-scroll/idi-p/1129540
Thanks!
