Geodata base help
3085
04-05-2015 04:36 AM
JB7
I have a question regarding the Geo database.
I am using parcel data from the state of CA. I downloaded the tax parcel and assessors information. I have create a land use code and joined it with the assessors informations state use code. This was successful and I was able to get the land use data into the attributes tables. I dropped the join but now need to export the data into a new geo database.
My question is when exporting each land parcel is there a way to append it and create a field like residency that reads yes or no. I need to know if the land use code that was generated is in a residency zone.
Could someone please help me with this?
thank you in advance!
JoeBorgione
I think you should just re-join the data and export it out.  If that's what you want, an additional feature class. Otherwise you can use a relationship class and access the data that way.
That should just about do it....
