Visibility in airspace
631
11-07-2013 11:01 PM
TamasSandor
Hi Everyone,
I'd like to ask you for a little help.
My task is to make a visibility analysis in a 4 km radius area from two different observer position separately.
I use ArcGIS 10.0 and 3D Analyst and Spatial Analyst.
I have a DSM of the area and I have an 3D Shape file which contains the buildings in that area.
I also have the positions of the observers in XYZ coordinates.
The visibility analysis works fine on the surface, that's OK, I can do that using the Visibility Tool.
But I have to examine the 3D airspace above the area to 40 meters above the surface.
So my question is:
Is there a way to examine the visibility not just on the surface but in the airspace too?
Any suggestions how I should move forward could be helpful.
Thank you in advance.
Tamas
