Trim 3d surface by line or poly features?
3809
12-17-2014 01:10 PM
DavidMedeiros
I have a 3d density surface representing water sample data taken along a stream network.
I would like to visualize this as spikes just along the stream bed. Is there a way to take the surface I have and trim it to some linear feature (like a 10 or 20 meter river buffer), so the spikes remain but the edges are clipped or trimmed at the edge of the buffer?
I tired extracting the surface by the buffer and setting the base height to the extraction and that results in a ribbon of pixels at the Z value higher but there is no fill to the bottom of the surface (like an extrusion).
Tags (3)
JorgeOrellana
what comes to mind is creating a TIN from your data and using your buffer polygon as your clip so you only get the data inside the buffer distance you provide, you can  then convert that to a raster if you need it to be a raster.
See here for the the Create TIN tool ArcGIS Help 10.1
Cheers
