Showing 3d line of Power line _sagging of the power line
3211
10-21-2012 07:46 AM
ThillaiNadarajan
I would like to represent in 3d Schene the power lines with power poles and sagging of the power lines (curve downwords).
Please advise.
Tags (1)
TimBarnes
This would either need to be modelled (i.e. create a proper 3D model of powerlines with the sagging in) or if you are handy with python, you can write a script to model the Z shift of each vertex along the line by iterating through a list of offsets.
ThillaiNadarajan
Hi Tom,
Thank you.
I do not have experience in phython.
Regards
Thillai
DavidPetrey1
Only just saw this one and thought I would offer up a solution.
There are several steps to this:
-Get the points representing the towers holding up the wires (these may be the end points of each power line or you may hold them as a separate dataset) and give them an attribute representing the height of the power line at that location (eg 100metres)
-Get the mid points between the towers (there are various ways to do this �?? split the power lines in half or use trigonometry with the tower coordinates) and give these a value that the power lines sag down to (eg 80 metres).
-Combine the 2 point files into 1 dataset.
-Use interpolation such as IDW to create a raster surface using the height values chosen above.
-Use the raster surface created as the heights for your power lines in ArcScene.
Hope this helps. I actually use this technique in the 3D Analyst course I teach at work.
Please mark this as answered if it helped.
David
simplyGIS Ltd. Making GIS simple.
http://www.simplyGIS.co.uk/GISTraining.html
http://www.simplyGIS.co.uk/GISTraining/ArcGIS/3D.html
ThillaiNadarajan
Hi David,
Thank you.
I received a similiar reply from Jie also.
Regards
Thillai
