Setting Minimum Contour Length
1698
07-31-2012 08:37 AM
DavidDossey
Is there a way to set a minimum contour length?  I am contouring a mosaic dataset created from LIDAR and the resulting contour map is very "dirty."  In CAD software this can be overcome by setting a minimum contour length thus eliminating all of the little islands that should not be contoured.  ArcView 10.0 single user with 3D Analyst.
See attached
In the attached image the contour should be 1 single line.
