Lidar Class Code
1257
11-15-2012 01:59 PM
HollieClavering
I have many XYZ Lidar files which contain the class code prior to the co-ordinates i.e. 2 x y z.  How can I import this file and convert it to multipoint?
Thank you,
Hollie
Tags (1)
CamPatterson
I may be wrong, but don't know of way within ArcGIS to pull class codes into a multi-point from an ASCII file. You can probably do it in a stand-alone python program using the liblas library of python LAS processing tools, to create LAS files with class code, then pull them into multi-points using the 3D Analyst LAS-to-Multipoint GP Tool http://www.liblas.org/tutorial/python.html
JeffreySwain
You also might consider the LAS Tools and specifically the txt2las tool.  There is also the option to convert to an LAS with ArcMap using Data Interoperability.
