LIDAR analysis
5815
11-16-2010 12:57 PM
SisiraEdiriweera
Hello
I would like to know how to use ArcGIS tools (3D) especially for filtering and interpolation of LiDAR (LAS 1.2).  I would be grateful if anyone would help me
Sisira
Tags (1)
JeffreyEvans
For interpolation you will need to convert your LAS data to a terrain feature class. Unfortunately, I am not aware of filtering or classification algorithms available in ArcGIS without 3rd party extensions.
Here are some lidar processing software options that you may want to investigate.
FREE
ALDPAT
http://www.csc.noaa.gov/digitalcoast/tools/aldpat/index.html
FUSION
http://www.fs.fed.us/eng/rsac/fusion/
Multiscale Curvature Classification (MCC)
http://sourceforge.net/apps/trac/mcclidar/
COMMERCIAL
LP360 for ArcMap
http://www.qcoherent.com/
Toolbox for Lidar Data Filtering and Forest Studies (TIFFS)
http://globalidar.com/default.aspx
VG4D Production Manager
http://www.virtualgeomatics.com/solutions2.html
VLS lidar Analyst
http://www.featureanalyst.com/lidar_analyst.htm
SisiraEdiriweera
FREE
ALDPAT
FUSION
COMMERCIAL
LP360 for ArcMap
VLS lidar Analyst
Hi Jeffrey
Thanks for your reply. let me look over the software. Thanks again
MIchalBularz
unless your .las (lidar file) came pre-classified by the source, or has intensity values then the method is a lot more difficult.
Depending on what you are trying to do you can logically extract components such as buildings with the slope tool (building walls have steep slopes) or differentiating trees from buildings with the curvature tool (trees turn into less smoother surfaces) etc. These kinds of things are partially what the third party extensions use.
GordonSumerling
Sisira,
Check out the following white paper:
http://www.esri.com/library/whitepapers/pdfs/lidar-analysis-forestry-10.pdf
It will step you through taking lidar data from LAS 1.2 files through to a geodatabase terrain to perfornining analysis with 3D Analyst.
Cheers
Gordon
