HEC-GeoRAS
1518
01-06-2011 07:49 AM
ClayKimmi
I am having problems with the Extract GIS Data function in HEC-GeoRAS version 4.2.93.  The export tool will create a xml file but it will never create the sdf file.  Does anybody know how to fix this?
Tags (1)
ChrisCarlson
I'm fairly sure the .sdf file is created before the XML in HEC-RAS.  If you are looking for the SDF file I suggest you get into HEC RAS, open the project and export out the GIS data.  From the HEC-GeoRAS will convert the .sdf to a .xml file, and then you go into layer setup etc...to finish creating the GIS data in ArcMap.  Clear as mud?
