Labeling in ArcScene
5133
11-10-2013 07:10 AM
TimHayes
I know you can manually type in 3D graphic labels inside ArcScene. Given that you cannot click on a label with your mouse and rotate it, instead you must manually enter the XYZ position using the 3D Graphic Toolbar. This is a mind-numbing tedious process.
When using ArcMap, you can automatically label features based on an Attribute Field. Is there a way to do something like this in ArcScene? I mean use Feature Linked Annotation or is the only option to manually type the labels one by one as graphics.
Tags (1)
