IsClosed3D in arcObjects is not working
1708
08-06-2012 05:06 AM
kamilkhan
I am trying to check  multipatch geometry whether it is close or not. I applied isclosed3D and checked with output feature class by writing in database, there is no any addition of attribute with flag telling close or not. Any help will be appreciated.
Tags (1)
PavanYadav
Greetings,
The tool adds a new field (called IsClosed) that specifies whether the multipatch is closed is added to the input multipatch feature. Yes for closed and No for not closed.
Regards,
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
kamilkhan
Greetings,
Regards,
Pavan
Thanks for response. Am I doing something wrong ? Can you please guide...
multipatch_1 is my multipatch geometry.
IsClosed3D isclosed=new IsClosed3D(multipatch_1);
     Object obj=isclosed.getInFeatureClass();//I checked with outfeatureclass but it is read only
     IFeatureClass fc=new FeatureClass(obj);
     IFeatureCursor ifccursor_=ifcin.IFeatureClass_insert(true);
   IFeatureBuffer ifcbuffer_=fc.createFeatureBuffer();
   ifccursor_.insertFeature(ifcbuffer_);
   ifccursor_.flush();
after writing this feature class when I check back its attributes then there is no any addition of field "IsClosed".
thanks in advance.
PavanYadav
Hi Kamil,
Still not sure what you are trying to show with that code. My  coworker shown me the following and could see the field added:
GeoProcessor gp = new GeoProcessor();
IGPUtilities gpUtil = new GPUtilities();
String multipatch_1 = "C:\\arcgis\\ArcTutor\\3DAnalyst\\Exercise9\\GeoDatabase\\Lincolns.gdb\\Buildings";
IGeoProcessorResult gpResult = gp.execute(isclosed, null);
if (gpResult.getStatus() == esriJobStatus.esriJobSucceeded){
   for (int i = 0; i <= gpResult.getMessageCount() - 1; i++){
      System.out.println(gpResult.getMessage(i));
   IFeatureClass fc = gpUtil.openFeatureClassFromString(gpResult.getOutput(0).getAsText());
   int fieldIndex = fc.findField("isClosed");
   if(fieldIndex != -1)
      System.out.print("isClosed Field created at index: " + fieldIndex );
Thanks
Pavan
Pavan Yadav
AI for Imagery
kamilkhan
thanks a lot. I was just trying to learn using these tools in java.
thanks again.
