Line of Sight with Observer Height
1118
08-03-2012 09:21 AM
SaraMayberry
I can construct Lines of Sight with no problems if I leave the values for the Observer and Target Heights at None.  Of course this isn't too helpful when you're talking about wanting to know who will have view of a cell tower being built since cell towers are not 0ft tall.  When I rerun the tools to create the Lines of Sight using a Height field, I end up with all red lines.  No green whatsoever.  Any ideas on what I'm doing wrong?  It works fine if I use the 3D Analyst Toolbar Create Line of Sigh button with the height value changed, but I dont want to draw that many lines by hand.
Thank you for any input!
Sara
Tags (1)
PavanYadav
Please see Jeff Swain's reply at this forum. Example: your DEM has elevation range between 150 and 2000 meter and when you create a point for a200m high tower that is located at a 300m above the sea level location (on the DEM value is 300m), you should use 500m not 200m height. A 200m high point for 300m elevation location will be below the surface.
Regards,
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
