Intersect 3d line with a raster surface
11225
10
05-18-2011 08:52 PM
JustinFischer
I have created a raster surface that is made up of elevation (z) values.  I also have pts  with z values that fall above and below this 3d surface.  These are consecutive pts that in certain instances pt 1 may be below the raster surface and pt 2 may be above.  What I need to do is connect these pts (and many others) with a line and find out where that line intersects the raster surface and extract that raster value for that cell.
Any help would be much appreciated.
Justin
Tags (1)
KateDoughty1
Kudos! Over a decade later and this solution was still exactly what I was looking for! I had tried with raster but per your suggestion, tried multipatch and it worked perfectly.
Thanks, Eric!
