How to use tool "Sun Shadow Volume"
7879
13
01-21-2015 06:17 PM
Syamsuri_Satria
Hello...i have problems about using tool "Sun Shadow Volume" In ArcScene 10.1.
i use feature (shp) extruded 3D layer
then i use tool "Sun Shadow Volume" with data :
     - Start date and time : 1/22/2015 6:00:00 AM
     - End date and time : 1/22/2015 5:00:00 PM
     - Iteration interval (optional) : 1
     - Iteration unit (optional) : hours
but always it don't succeed..
Thank You.
Syamsuri_Satria
Hi. Mr. Kishor Ghatage
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2FGLWVQ1uH8WI8E0R8ibgcuIG7nlQ6K3UrAI2u2MG3MX1kE6WduzsGXQEv5teQZLNk-3D_eDTyoq4gcI2sthplpZMwqm4VqzJdyfqOeajQI9nHwnh5S-2Byqw9Hx8XoB4ANbqrLYG1xKU-2FzhMgD0DvFd70TbzZXWGobfxdC1ddllDlAntYc2fscaU94NUkaEc5ybtnDo3Z72wQxVXUk7nfysXhLsye-2F-2FSU-2B-2B-2F5MEq1-2BUGwp3v3CLs-2Bw9xAgcGi7vx3w53ODJ-2B2rh6foAL4R-2Fox-2BA9o-2FvQk4GdtZ7Fwg8HAUSTSgWxrDlN9p1rlbI2ALiKb9l3Vd16P-2Fu6aNAsQszQK6tj-2BmSLavTBZDv8J6XJuuAPvBavJ3Vm41Y5As-2BQp4zdvd-2F-2B4mlyge8TjQuVeTSYz4LJXhoew-3D-3D>
thanks for helping me
this my file is multipatch feature for testing.
Zona Time (UTC+07:00) Bangkok, Hanoi, Jakarta
Thanks for All.
KishorGhatage
Occasional Contributor III
I tested the behavior using provide data. After defining the coordinate system tool worked as expected.  Please define the correct projection of your data and run sun shadow volume tool.
Steps:
1. Open ArcCatalog window / ArcCatalog
2. Navigate to multipatch feature class > Right click > properties > XY Cordinate sytem
3. Choose appropriate Projected Coordinate system > Click Ok
4. Use Sun Shadow Volume tool.
StephenKnox1
Fixed it by defining the projection of the data. Better error messages would be go though please ESRI.
Stephen
YingYeung
New Contributor II
Finally, I was created the shadow successfully but I do not understand the meaning of "iteration interval" and "iteration unit".
Can anyone explain it? Thanks a lot!!!!
