How to let the Length3D get in used with the shortest path analyst in ArcScene
2391
06-08-2013 11:26 PM
by Anonymous User
Not applicable
Original User: cowshut
I have go throw the tips from helping center and build up a model builder for it.
(http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00470000005q000000)
And the problem is, if there's a vertical edge, it can not be solved.
I guess the tool gets the information from "Length" properties not the "Length3D".
How to let the Length3D get in used? or the I should change the method?
Here is some sample run.
It works in the same plane
[ATTACH=CONFIG]25156[/ATTACH]
[ATTACH=CONFIG]25157[/ATTACH]
but when it need to go across plane, it failed.
[ATTACH=CONFIG]25158[/ATTACH]
[ATTACH=CONFIG]25159[/ATTACH]
thx.
cowshutyang
hi, I really need some help. Does someone can help?
or the information is not enough can also let me know, thx.
by Anonymous User
Not applicable
Original User: Hornbydd
Can you upload your data and model, this may help others to help you?
cowshutyang
Here is the shape file and network dataset file.
The diagonal line is set for checking my model builder is work or not.
http://goo.gl/zaQfY
