Flip stream polylines based on preliminary DEM
3060
11-15-2010 03:18 AM
AgnarRenolen
I want to generate a DEM using Topo to Raster and using the stream data, but my streams are digitized both up-stream and down-stream.
But, if I generate a preliminary DEM without using the streams, I might use that DEM to automatically correct the stream directions based on the elevation at each end of each stream line.
Has anyone made a script/extension that does this?
Agnar
JacquesTardie
You're working with a topo layer and and separate stream layer, or is this from a single layer?
by Anonymous User
Not applicable
Original User: jakubsisak
Agnar
I am pretty sure the Topo to Raster tools needs the streams to be 3D polylines otherwise it will not work correctly.  If you just need to flip the orientation of the line then select it while editing, right click and flip.
