Fade out Key Frames
1785
10-24-2022 01:04 AM
BruceBurwell1
Good Morning all
I am trying to add a beginning and ending key frame to my animation that will just fade in and then fade out at the end. Is that something that is easy to do?
Thanks
Bruce Burwell
DanPatterson
MVP Esteemed Contributor
from Use the Animation Properties pane—ArcGIS Pro | Documentation
under layer properties step 4
Use decreasing transparency values in successive keyframes to fade layers in, or increasing values to fade layers out.
... sort of retired...
DanPatterson
BruceBurwell1
Thanks Dan
That kind of works. I really want the slide to fade to black.
