Distance vs. Distance
667
04-01-2013 11:01 AM
SaschaSchneiderwind
Hi there,
I did some profiles via "interpolate line" and noticed, that the "Distance" is already the length of path and not air-line distance.
Is there any possibility to change this setting?
You know, for the Measure-Tool you can switch between "Planar" (which is the length of path) and "Geodesic" (which is the air-line distance).
Or do you have an idea to evaluate once from the other?
Cheers and thanks!
Tags (1)
