CityEngine and management of the RAM
3444
02-02-2016 06:25 AM
reitsined
Hello;
What are the two memory indicators located at the bottom right of the screen?
What do they indicate more precisely?
Does he has the ability to change the amount of RAM allocation in managing CityEngine?
Thank you and good day
DanPatterson_Retired
don't see anything obvious in help Help -
You might just want to scroll around the interface section
User Interface
DavidWasserman
Hi Reit,
This has previously been answered by Matthias Buehler here:
https://community.esri.com/thread/50380 From link:
those two indicators show the 2 memory types CityEngine uses : Java memory (left) and Native memory (right). [ CityEngine is written using 2 programming languages : Java and C++ ]
Thus you're running out of Java memory.
The reason for this is that Java reserves a certain amount of memory for CityEngine and this memory can not be used for any other application. Due to this fact, the developers had to agree on this certain amount of memory which is okay for most users. Some users with big datasets may - as you - run into issues with this. But of course this amount can be set. (PM me to get instructions)
Though editing this amount has it's risks if the user's not perfectly aware of the steps taken.
To get an overview of how much the VRAM is used, check :
Help > About CityEngine > Installation Details > System Info > OpenGL
David Wasserman, AICP
