Change Units on Profile Graph
6796
03-02-2012 10:51 AM
JasonDeshaies
Does anyone know how to change the distance units on a profile graph (bottom axis)? Currently the units are in meters and I would like it to be in either feet or miles. I looked under properties and advanced properties but could not find where to change this. Thank you in advance!
Tags (1)
TarunJaiswal
Greetings!
Please change your map units within the data frame properties.  First, go into the Data Frame Properties  >  Coordinate system > Modify. Under Linear unit, select your desired unit (feet or miles).
Next, go into the General Tab and change the units again to your desired unit (feet or miles).  Then create you profile graph.
Hope this helps.
Thank you.
TarunJaiswal
Greetings!
Hope this helps.
Thank you.
JasonDeshaies
I totally forgot about the modify button for the coordinate system...thank you!
CalvinDwight
Thank you. It is useful!
