ArcScene resolution confusion
1949
5
05-23-2011 09:13 AM
ChristopherJursa
I am using ArcScene with ArcGIS 10.
I have a raster image I have krigged.  Whenever I load the layer into ArcScene, it loads fine.  However, when I attempt to change the symbology, the resolution of the layer becomes low as if there is an error.
I have two other rasters in different projections.  Could this be the cause?
Has anyone encountered anything like this?
Tags (1)
TimothyHales
Esri Notable Contributor
Try adjusting the "Quality Enhancement" setting to see if the resolution improves.
Optimizing raster and surface layers
ChristopherJursa
That didn't seem to help.
TimothyHales
What type of symbology changes are you doing?  Does the raster display better before changing the symbology are is it the same?
ChristopherJursa
Thanks for the help so far.  I don't think the quality enhancement is the issue either.
I opened a second ArcScene window and loaded the layer and had no difficulty with it.  I then copied it and pasted it into the first ArcScene project.  This seemed to solve the problem.  It is a strange workaround though.
I think there is an issue with the projection of the data frame.
JeffreySwain
I recommend keeping all of the layers in ArcScene  in the same projection. Since ArcScene is so memory intensive, there can be issues when a transformation needs to take place.  Keeping the projection will prevent some of the potential display issues you are describing.
