[ArcScene 10] - visualization of contours in 3D
3032
12-03-2010 09:09 AM
delap
First of all, I am a beginner in ArcGIS and my english is not perfect, so just be understanding !
I would like to visualize in 3D (in ArcScene) some contours that I have built in ArcMap.
I will explain you what I have done :
1- from an XYZ files I built a Raster with an interpolation tool
2- from this raster I built a contours files (shapefile)
Now I want to see this file in ArcScene but it doesn't work. I try to use the "Feature to 3D by attribute" tool which is in 3D analyst tools> 3D features. maybe I mess a step...
Can you help me please ?
Thank you very much !
Delphine
Tags (1)
JakubSisak
Honored Contributor
Do you not see the data in ArcScene at all? Or are you just having an issue with visualizing it in 3D?
Did you set Base Height to the elevation field in the contour layer?
