ArcGlobe Extent
1116
11-11-2010 07:17 PM
rohandontireddy
Iam trying to build WPF windows application using ArcGlobe Below is the code for ZoomIn functionality using Active View,zooming is working properly.but my need is i need to capture the Globe Extent but always im getting same values as -89,-179,-79,-169 as MinX,MinY,MaxX,MaxY respectively.
is there any other way to do this ?
//Zoomin Code using Active View
double vfa = 0;
m_Camera = m_ActiveView.Camera;
vfa = m_Camera.ViewFieldAngle;
m_Camera.ViewFieldAngle = vfa * 0.9; //vfa * 1.1 for Zoomout
m_ActiveView.Redraw(true);
IActiveView actview = globeControl.Globe as IActiveView;
actview.Refresh();
MinX = actview.Extent.XMin;
MinY = actview.Extent.YMin;
MaxX = actview.Extent.XMax;
MaxY = actview.Extent.YMax;
Tags (1)
BryanKardisco
You ever figure a solution out to this?
maria_josemontoya
I need to capture the Globe Extent but always am getting same values as -89,-179,-79,-169 as MinX,MinY,MaxX,MaxY respectively. Why? Have you solved your problem?
Maria Jose
