theory of create steepest path??
1841
03-10-2011 04:18 PM
hoho
Dear All
Does anyone know the backgroud theory of the function "Create steepest path" of 3D analysis
i can't find any document from the help.
the reason why i need to know is because i found that when i use a GRID file (DEM) to create the path by those function, the results sometimes is different compare with by using fow direction (Arc-Hydro).
also i find that the vertices of steepest path created by those function is not along the center of the GRID, sometime is change direction within one cells
Many Thanks for help
Regards
Roy Ho
Tags (1)
