Missing Data for Exercise 5
1150
03-16-2011 08:32 AM
marcusbouterse
I am trying to use the Desktop 10 "exercise 5:working with animations" tutorial  under the 3D analyst tutorial exercise from the resource help center but am unable to find the data/files that relate to the exercise.  The section prior mentioned a ArcTutor folder within the ArcCatalog, but this folder I was unable to find.  Any ideas were I might be able to get the needed files to run through the exercise?
Tags (1)
TimothyHales
Esri Notable Contributor
The data is a separate install and should be with the installation media.  If you downloaded the install files then it should be found there.
