Adding an empty or populated multipatch feature class into ArcScene or ArcGlobe
2156
05-28-2012 10:02 AM
JohnMorgan
I am working through the process of moving SketchUp models into and out of ArcScene/ArcGlobe.  I have learned that collada is the the best file format for doing this.  I now know you can use Import 3D Files to pull in the collada file.  However, I was just curious if it is possible to create a multipatch file within ArcGIS by itself.  When I go through the Create Feature Class process multpatch is not a geometry type in drop down.  Any assistance would be appreciated.
P.S. I realize now that I misspelled ArcGlobe in the subject but.
Thanks ahead of time,
Derek
Tags (1)
TimothyHales
Esri Notable Contributor
You can right click on a geodatabase or folder > New > Feature Class/Shapefile.  Then choose multipatch as the type from the drop down.
Multipatches
TimothyHales
Multipatches
JohnMorgan
Thanks Tim.  That did answer my question.
Cheers,
Derek
JohnMorgan
Tim I would like to mark this question as answered. Do you know how I would do that?
Derek
TimothyHales
When you are logged in, there should be a check mark to the right of the post.  Selecting the check mark will turn it green and it will show as answered.
