3D Doc
6381
29
03-04-2010 02:57 PM
TedCronin
http://help.esri.com/en/arcgisdesktop/9.4/help/index.html#/A-quick-tour-of-3D-Analyst/00Q80000000300...
The 3D Effects toolbar
There should be some text to show what application that each toolbar belongs too.  I had to find the swipe tool, to determine this fact.  It would be nice to just have some sort of bold text stating this:
ArcGlobe:
ArcScene:
Tags (1)
TedCronin
It would be nice to have an interactive snapping tolerance tool, where there is a 3D circle around the cursor that one can draw interactively to define the tolerance, but the feedback to us, would be a 3D circle that grows from the center of the user click.
The 2D version is created from a point click and draws outward, but on a flat plane.
The 3D version we could see in 3D, perhaps as part of 10.1.
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/How_to_change_the_font_of_3D_text_graphi...
Just prior to step 4:
You can also click the text properties button  after selecting the 3D text to invoke theDefault Text Element Properties dialog box.
Space between the Default
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/How_to_change_the_location_of_3D_graphic...
It seems like this help doc is about setting Size and Position, but the graphic does not show the size and position form, it does show the tab, but it seems like the actual form should be shown.
A Graphic Change
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/Interactive_TIN_Editing_tools/00q8000001...
TIN Editing toolbar drop-down menu options
There are no hyperlinks for any of the options on this doc:
Start Editing TIN
Stop Editing TIN
Save
Save As
Undo Since Last Save
Set to Constrained Delaunay
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/The_ArcGlobe_user_interface/00q800000091...
The graphic shows a List by Selection on the TOC, so is this coming at Pre Release or is this an older prototype view?
TedCronin
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/Navigating_in_ArcCatalog_s_3D_preview_wi...
the Navigate Icon and Full Extent Icons in the doc appear to be from 93
TedCronin
TedCronin
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/Creating_intensity_images_from_lidar_in_...
The graphic on this page showing a table is from 93 and should be consistent with 10.
