3D Analyst
1346
10-26-2009 08:33 AM
Gert_van_Maren
Esri Alum
Original Post Date: Oct 26, 2009 9:33 AM PDT
9.4 3D Analyst is a huge release for doing GIS in 3D. It extends ArcGIS to be a fully functioning 3D GIS system �?? create, manage, analyze and share 3D GIS data.
Whats' new?
  • In 9.4, we added editing in 3D so you can create and maintain 3D GIS data, such as a virtual city.
  • 9.4 will have a 3D City Template. This will show you how to build your own virtual city easily.
  • Huge improvements in analysis of 3D vector features which allows you for example to:
  • - analyze the skyline of a city.
    - do advanced 'line of sight' analysis to determine visibility along a parade route.
    - calculate buildable volumes -> determine the maximum height and extent of buildings so they can't been seen from the road.
    - calculate the impact of an explosion using union and intersect in 3D.
  • Vectors in 3D are faster and better
  • - lines can be draped on the globe surface
    - performance of textured multipatches is improved
    - no more overlapping annotation
  • Fast performance of 2D map caches in ArcGlobe reducing the need to maintain both 2D and 3D map caches
  • Improved integration with LIDAR sources making ArcGIS is a real solution for LIDAR.
There are also many usability enhancements for 9.4, including an updated navigation experience, simpler / easier authoring tools for publishing Globe services to ArcGIS Server, and extensive documentation on the best ways to author and interact with 3D views of GIS data.
In short, 9.4 makes ArcGIS a complete 3D GIS.
Let us know your experiences in using it!
Gert van Maren
Product Manager 3D
Tags (1)
CamPatterson
In browsing the help system I've picked out some of the improved Lidar data handling and processing capabilites, but would REALLY appreciate a concise review of the updates relevant to Lidar data handling in Terrains and multi-points, and point cloud analysis options using python.
For example, has access to and handling of LAS attributes like elevation, intensity and return no. in the multi-point data type been improved?
Gert_van_Maren
Esri Alum
Here is an overview of the updates relevant to Lidar data:
PointFileInformation GP tool: enhanced with option to output info on LAS files summarized (i.e., point count, spacing, z-range) by class code. Helps answer questions like - how many points in each LAS file are bare earth, what's their z-range, etc.
PointToRaster GP tool: enhanced to support LAS lidar attributes stored in BLOB fields in multipoint feature classes. Facilitates, for example, making intensity images.
All GP tools that supported TINs, with the one exception of ExtrudeBetween, now support terrains or have a replacement that supports terrains.
All terrain/TIN based tools offering interpolation (e.g. InterpolateShape) enhanced with new conflation options. Can be used, for example, to estimate shoreline height (e.g., lakes, rivers)  from lidar.
Append/Delete/ReplaceTerrainPoint GP tools support both embedded and referenced feature classes. Referenced feature classes properly update LAS BLOB attributes if present. These tools can also operate on polygon based areas of interest, not just rectangles.
Terrain dataset has new �??anchor point�?? option for critical points  such as control points, navigation hazards, etc., that are guaranteed to remain present throughout all pyramid levels; they never get thinned/filtered away.
New TerrainToPoints GP tool enables you to produce thinned (multi)point datasets from full res datasets using terrain�??s z-tol or windowsize filtering algorithms.
New LocateOutliers GP tool to find points outside a user specified ceiling/floor height or that are significantly different than their immediate neighbors. Confirmed data blunders/errors can be passed into DeleteTerrainPoints to have them removed from the surface.
Terrain layer has new contour renderer.
Terrain layer has new point renderers for embedded points with LAS lidar attributes. Can now symbolize points based on class code, return, intensity, etc.
New point profile tool can place points within proximity to a query line into a profile graph. Profiled points can come from either multipoint feature classes or feature classes embedded in terrains. The points can also be colored by LAS lidar attribute, e.g., class code.
Terrain overviews have been optimized to allow large terrains to be opened and viewed more quickly.
Regards Gert
CamPatterson
Thanks for the update!
