3D Analyst inaction menu
3790
05-22-2011 04:12 AM
boikoboiko
Hallo,
I use ArcMap version 10, i import a DWG fail with a geodesic survey of terrains in order to transform it in I arcview dwg polyline and i found deactivate option that i need ex: create TIN features, slope analyses and aspects analyst. Coud you provide me any solution in order to resolve that problem.
Tags (1)
EricRice
Esri Alum
Greetings,
Can you send a screenshot of what the problem is?
Eric
boikoboiko
This is my screen
JeffreySwain
Due to changes at ArcGIS 10, the toolbar now will become active once a raster is added to the map document.  The other tools that you are referencing are still available in the ArcToolbox interface, but no longer reside on the toolbar.  Here is a blog post discussing it in specific.  There is some help documentation on how to add the menus and tools back.
For the TIN Editing, you will need to have a TIN added to the map document.
