Cursor Stuck
1139
05-10-2019 07:17 PM
KerryDavis
My cursor is stuck as the magnifer tool. It will not let me change it. ? Arc 10.7 What do I do
Kara_Lara
Hi Kerry,
I had this same issue as well. Turns out it has to do w/ the tool you're trying to use getting "forced to the background" or something like that... that was the explanation I found. To bring your current tool forward, press "ctrl" + "shift." You should see your cursor switch from what it is stuck on, to the tool you currently have selected. It may not be an indefinite fix, but I hope it helps!
