How to load a secured wms layer with client certificate?
Hi, I'm new to ios app development and new to authentication stuff. Any help is very much appreciated. SDK version: Arcgis sdk for IOS version 100.7 I need to load wms layer from a secured https server with client certifiate, p12 format. Below is my code to get AGDCredential object. I can get SecIdentityRef as below, but…
search closest social security office using zipcode
Hello Could you please tell me the api to be use to search closest social security office using zipcode in USA, I want to use it in a website?
How to compare two fields from two different feature classes in arcpy
Hi Users, I have two feature classes, i.e FC1 with fields [C_PIN, IsSelected], and FC2 with field [PIN]. Now I want to update the field values of [IsSelected] for the rows in which [C_PIN] and [PIN] are same. Please share any sample code for my requirement. Thank you in advance.
ArcPy script for Select features on mouse click
I want to develope an arcpy add-in tool for select feature on mouse click in arcmap. I searched a lot but not found any sample code. Please some one help me the arcpy script for this tool I will be thank full, if any one post correct solution for my question.
Cursor Stuck
My cursor is stuck as the magnifer tool. It will not let me change it. ? Arc 10.7 What do I do
trouble facing with changing cell size to a desired resolution
please help me.when I create a polygon (the cell size is given 0.0031 automatically) and rasterize it, the cell size remains 0.0031, in angular degree. I projected it to convert it into meter, in the hope that the cell size will change. I tried to change it even during rasterize operation.the results were not fruitful. it…
problem with GlobalID
how to update in an existing global id records where the global id is Null? i am unable to do that
how to export map from GIS online into desktop arcgis 10.5 ?
I had drawn map in arcgis online and now i want to export this map to arc gis desktop 10.5 ? how ?
Arcs traversed in Shortest Path
I used Shortest Path from Network Analyst to calculate the shortest distances between multiple points. The result I get is the length of the paths, but what I need is the actual route in terms of arcs taken to get from source to destination point. I have read that shortest path uses Djikstra's algorithm to calculate these…
Arcmap 10.3.1 hungs on "Initializing Application" phase
Hello, Arcmap 10.3.1 hungs on Initializaing Application phase. it happens on Win7 and Win8.1 machines 1. normal.mxt renamed - no effect 2. ESRI folder renamed - no effect 3. Esriconnector.exe (or whatever, which lies in programfiles\common files\esri\arcmap\bin\connector) renamed - no effect 4. tmp and temp folders moved…
Bug? "Raster to Polygon" and "Extract Value to Point", Automatically add extension name, interrupt the procedure running.
Dear All: Recently, I spot a quite tiny error in ArcGIS 10.4.1 model builder. So far, I found two tools have this kind of error: “ raster to polygon” and “extract value to point”. The error is that the tool will automatically change the output name after running it first time. it will automatically add a “.shp” extension.…
Exporter vers shapfile code et description du Domaine
Bonjour, J'utilise une géodatabase avec plusieurs domaines, ensuite j'ai crée un shapefile contenant les éléments des domaines, ma question est la suivante: quand j'exporte le chapfile j'obtiens que les codes des domaines et non pas les descriptions veuillez SVP, me donner une idée pour exporter vers shapfile code et…
Load Data in Table through model
Hi, I want to load data in a Database table thorough model builder. so please tell me how to do this Thanks in advance. kapil
why does arcgis map not allow me to create a legend
when I go to the toolbar and in the insert tab the legend option is not available for me. How do I activate it and insert a legend to my map?
Test discussion 2 created by Chris
Test
Test discussion made by Chris
Test test test
Query not selecting what I need it to
Hello, I'm trying to run a simple query and I don't know why it's not working. I have a US cities shapefile with an "Population" field and I'm just running this: Select * FROM cities WHERE: POPULATION > '400000' But it doesn't select populations that are above 400,000. It seems to just select whatever it wants - including…
Petrel Well Symbol Mapping to ArcMap using OpenSpirit ArcMap Extension
Hi, We are using OpenSpirit ArcMap Extension to send well data from Petrel to ArcMap. The Wells in Petrel have a well symbol that are no correctly mapped in ArcMap during the well data transfer. How do we map the Petrel well symbol to ArcMap so when you transfer the wells they are correctly mapped. We are using Petrel…
TruPulse 360-R to work with ArcGIS for Windows Mobile running on a Windows 7 tablet
Is s possible to configure the TruPulse 360-R to work with ArcGIS for Windows Mobile running on a Windows 7 tablet I can find a rangefinder extension that can run on windows mobile platform
Austausch und Präsentationen
Für alle Interessenten und Teilnehmer des Workshops "ArcGIS - die Plattform für Kommunalverwaltungen", der am 23.10.14 in Hannover stattfindet, haben wir den Bereich Maps und Apps in Kommunen eingerichtet. Dort finden Sie weiterführendene Informationen, die Präsentationen und Ergebnisse der einzelnen Beiträge sowie die…
"ArcGIS - die Plattform für Kommunalverwaltung"
Die Esri Veranstaltung „ArcGIS – die Plattform für Kommunalverwaltungen, Workshop für GIS-Koordinatoren und Anwender“ findet ab Okober 2014 bundesweit in mehreren Regionen statt. Die nächsten Termine sind der 23.10.14 in Hannover und der 29.10.14 in Münster. Weitere Veranstaltungen sind u.a. in Köln, Potsdam, Leipzig,…
