Bug? "Raster to Polygon" and "Extract Value to Point", Automatically add extension name, interrupt the procedure running.
549
11-08-2016 03:19 AM
GuohanZhao
Dear All:
Recently, I spot a quite tiny error in ArcGIS 10.4.1 model builder. So far, I found two tools have this kind of error: “ raster to polygon” and “extract value to point”. The error is that the tool will automatically change the output name after running it first time. it will automatically add a “.shp” extension. As the result, the whole process will be interrupted by this because my output work space is gdb file. So the output cannot write into the workspace when I run it for the second time, until I manually delete the file extension name.
first time run the tool, every thing is fine
second time running the model, the output file name will be automatically changed.
the automatically added extension name will derive this error. So I have to change it for another time.
