Context menus/tabs should not differ when editing a single symbol and when editing multiple symbols in the same feature class.
What I think
When developing symbology, it is often useful to be able to edit many symbols at once. The ability too do so increases efficiency, and ensures consistency in the symbology being developed. While developing symbology, it can be deasy to overpopulate the 'styles' workspace with un-finalized versions of various symbols. For this reason, saving to a symbol to a style is not the preferred method.
The Menus
In ArcMap 10.X, the symbol editor was identical when you were editing 1 symbol, and when you were editing multiple symbols. In ArcGIS Pro, when you are editing 1 symbol you have access to the Symbol Tab, the Layers Tab, and the Structure Tab. However, when you are editing multiple symbols (via 'Symbology' pane> 'More' drop down> 'Symbols'> 'Format all symbols') you only have access to the Symbol Tab.
Current Setup
When Editing a Single Symbol (Unique Values)
.png)
Available Options
| Feature Type | Symbol Tab Options | Layers Tab Options | Structure Tab Options |
| Point | Scale Based Sizing Appearance Halo | Appearance (for each Symbol Layer) Position (for each Symbol Layer) Rotation (for each Symbol Layer) Offset distance (for each Symbol Layer) | Symbol Layers |
| Polyline | Scale Based Sizing Appearance Line Width | Appearance (for each Symbol Layer) Offset effect (for each Symbol Layer) Dash effect (for each Symbol Layer) Caps & Join (for each Symbol Layer) | Symbol Layers |
| Polygon | Scale Based Sizing Appearance | Appearance (for each Symbol Layer) Offset effect (for each Symbol Layer) Dash effect (for each Symbol Layer) Caps & Join (for each Symbol Layer) Pattern (for each Hatched, Gradient, and Picture Symbol Layer) | Symbol Layers |
When Editing Multiple Symbols (Unique Values)
.png)
Available Options
