Access All Editing Tabs When Editing Multiple Symbols
9302
15
01-17-2019 10:35 AM
Status: Under Consideration
ZacharyRoy
Context menus/tabs should not differ when editing a single symbol and when editing multiple symbols in the same feature class.
What I think
When developing symbology, it is often useful to be able to edit many symbols at once. The ability too do so increases efficiency, and ensures consistency in the symbology being developed. While developing symbology, it can be deasy to overpopulate the 'styles' workspace with un-finalized versions of various symbols. For this reason, saving to a symbol to a style is not the preferred method.
The Menus
In ArcMap 10.X, the symbol editor was identical when you were editing 1 symbol, and when you were editing multiple symbols. In ArcGIS Pro, when you are editing 1 symbol you have access to the Symbol Tab, the Layers Tab, and the Structure Tab. However, when you are editing multiple symbols (via 'Symbology' pane> 'More' drop down> 'Symbols'> 'Format all symbols') you only have access to the Symbol Tab.
Current Setup
When Editing a Single Symbol (Unique Values)
Symbology pane when editing a single symbol in ArcGIS Pro 2.0.1 (polyline symbol as example).
Available Options
Feature TypeSymbol Tab OptionsLayers Tab OptionsStructure Tab Options
Point
Scale Based Sizing
Appearance
Halo
Appearance (for each Symbol Layer)
Position (for each Symbol Layer)
Rotation (for each Symbol Layer)
Offset distance (for each Symbol Layer)
Symbol
Layers
Polyline
Scale Based Sizing
Appearance
Line Width
Offset effect (for each Symbol Layer)
Dash effect (for each Symbol Layer)
Caps & Join (for each Symbol Layer)
Symbol
Layers
Polygon
Scale Based Sizing
Appearance
Pattern (for each Hatched, Gradient, and Picture Symbol Layer)
Symbol
Layers
When Editing Multiple Symbols (Unique Values)
Symbology pane when editing multiple symbols in ArcGIS Pro 2.0.1 (polyline symbol as example).
Available Options
Point
Scale Based Sizing
Appearance
Halo
Polyline
Scale Based Sizing
Appearance
Line Width
Polygon
Scale Based Sizing
Appearance
15 Comments
DavidWheelock2
This is an important ArcMap Equivalence issue.  This is not just some new feature that users want.
Why was this not implemented years ago?
This issue should have been placed In Product Plan in 2019 when it was first brought to ESRI's attention.
EdiePunt
Hello @alfrenjeru. I wanted to reply re your comment: https://community.esri.com/t5/arcgis-pro-ideas/access-all-editing-tabs-when-editing-multiple/idc-p/1...
You absolutely can edit the outline of a polygon symbol now. You just need to edit the properties of the stroke symbol layer(s) that are part of the polygon symbol. But yes, this particular idea is about editing multiple symbols at once, and those properties are currently unavailable in a multiselect case, until we address this idea.
EdiePunt
@DavidWheelock2 Thank you for your input in this comment: https://community.esri.com/t5/arcgis-pro-ideas/access-all-editing-tabs-when-editing-multiple/idc-p/1...
I agree with you that this is important functionality and we are also keen to provide it in ArcGIS Pro. It is not something that we overlooked or were unaware of. As you know, the symbol model in ArcGIS Pro is different than the one used by ArcMap, so the symbol schema is different. There's a lot behind this particular functionality to ensure that it operates properly in all cases.
RTPL_AU
Currently when trying to change the symbology for all items in a thematic map you can only change the line width and colour.
Please update Pro so that you can edit all aspects of the style, as you can for a single item.
AlfredBaldenweck
Please add this.
Current workaround is to save a symbol to a style and use that, but I frequently wish I could just edit them like a single symbol.
