How to programatically add symbols to a .stylx (Styles) file and apply that symbology to a feature layer
15481
11
03-27-2020 03:41 PM
I was recently working on a project that needed something like 100 unique symbols. Each symbol was a circle or square with a four letter code on it. This is something that lent itself perfectly to being done programatically. I really didn't want to have to generate those symbols one by one, so I started searching of ways to do this programatically, but didn't find much information on how I might get this done using Python.
The first glimmer of hope was when I found how to apply symbols from style gallery (i.e. Favorites or project Styles .stylx). I had accepted the fact that I'd just programatically create a bunch of png's, add them to my Favorites, and then write some code to apply the symbols in my Pro project. Then I stumbled upon an Esri blog post that mentioned that .stylx files are just SQLite databases. This got me thinking that I'd be able to further program the generation of these symbols.
I used DB Browser for SQLite to take a look at the structure of the .stylx db. Most of what you need is stored in the ITEMS table. There's a content field where the json representation of the symbol is stored. For some reason, the json string has a character at the end that makes DB Browser think it's a blob instead of text. If you delete the 00 at the end, it will then display as text and you can get an idea of what the json looks like for a CIMPointSymbol for example.
Things to know about the .stylx file:
  • both ID and KEY have unique constraints, so make sure the rows you add to the database comply with these constraints
  • CLASS is the type of things your adding to the .stylx - I didn't investigate all the options, but I do know 1 is a color and 3 is a symbol
I broke my code up into two python scripts. Here's the pseudocode and some real code for each script:
Generate symbols - programmatically generate symbols and add to your Favorites .stylx
  • read symbol information from excel file into a pandas df (things like fill color, border color, text for symbol, etc.)
  • read in a template json from a text file - instead of generating all the json, I just modify this template by changing things like fill color, border color, etc
    • I created this template by creating a symbol in my Favorites.stylx, viewing it in DB Browser, copying the json, and saving it to a .json file
  • connect to the .stylx using sqlite3 (conn= sqlite3.connect(db))
  • iterate through the rows in my df
    • modify my json from the template
    • create a new row to add to the db
      • new_row = (new_id,3,'',code,'rgb;black',json.dumps(new_sym),code)‍‍‍‍‍
        execute sql code to insert row into db
      • cursor.execute('INSERT INTO ITEMS(ID, CLASS, CATEGORY, NAME, TAGS, CONTENT, KEY) VALUES(?,?,?,?,?,?,?)', new_row)
        commit changes to db and close db
At this point, I now have a bunch of new symbols in my .stylx file. While testing I worked on a copy of my Favorites.stylx, but as long as Pro is closed, I don't think there's any issues with working on the real file in its default location ("C:\Users\userxxxx\AppData\Roaming\ESRI\ArcGISPro\Favorites.stylx"). Just make sure you have a backup copy of it just in case you ruin it.
Apply symbols - as long as the name of your new symbols matches the symbol item values in your Pro project, it's relatively easy to apply the symbology programmatically
  • read in map, layer, symbology from a Pro project
    • m = p.listMaps('Map')[0]
      lyr = m.listLayers("layer name")[0]
      sym = lyr.symbology
  • iterate through symbol groups and symbol items in each group and apply symbol, as long as there is symbol in the gallery with the name of your item's value, this should work
    • for grp in sym.renderer.groups:
          for item in grp.items:
          item.symbol.applySymbolFromGallery(item.values[0][0])‍‍‍‍‍‍
  • set lyr.symbology to the sym that was just modified (I forgot to do this and it took me forever to figure out why my symbology wasn't getting applied)
  • save the project
I hope this helps someone that found themselves in the same position that I was. If anyone needs any more details on how this was done, just let me know.
Here's a list of posts that I found while searching how to do this
Importing Custom Point Symbols
Custom Symbols for AGOL
Creating a .style file
Assigning an icon from a .stylx file and rotating it, in arcpy
Comments
HollyBaun1
Thank you for sharing this! I have about 70 unique polygon symbols in a layer and have been trying to find an efficient way to get them into a style. I probably could have manually saved each symbol to a style in the time I spent searching for a different way, but I know I have other symbols/layers in a similar situation. I hope to try your method.
JimmyKnowles
Holly, glad this was helpful for you. Let me know if you run into any roadblocks if you try this out.
krisDupond
New Explorer
I believe your solution approaches is what I need after a lot of research (Pro 2.7.1) which include apply symbols from style gallery, and examples like Restaurant or Python_CIM_Access. Your method seems to be the only current solution to my problem but I am not sure that it is the right and only possible way. So I would like more details or just advices.
But in the previous cases (links) it is often a question of superimposing symbols and not of automatically creating a symbol with several layers as my goal is to automatically create a legend (.lyrx) of 500 polygon symbols which have each 5 layers. Each polygon has a five characters tag identifier (eg "A1234"). Each character determines the symbology of a layer according its place in the idientifier : the first character fix the solid color of the first layer, the second is used for colored hatch of the second layer, the last three layers have a single and different text marker (like "T" or whatever). The hatches and markers are colored and rotated according to the color and angles read in an attribute table (colors, angles).
This table can therefore be read with pandas df (Python). But I have a few questions in the part "Generate symbols" : 1) will the template need to be created with a single 5-layer symbol (.lyrx), then renamed to .json? 2) I don't understand after "Connect to .stylx like using sqlite3" what ".stylx" is refering about (the new .json ?) ? 3) Is it really possible not to start with a military style .lyrx (MIL *)? 4) Do you think my problem might actually be solved with your method? 5) How should I proceed to program the “Generate symbols” part as automatic as possible?
Thanks for your advices.
Regards
krisDupond
New Explorer
Forgot the "links" :
apply symbols from style gallery, and examples like Restaurant or Python_CIM_Access_Samples
HeinrichB
I am desperately looking for a way to convert Symbology Encoding to ArcGIS Pro .Stylx do you have any idea for me?
KarstenRank
great way to create styles from images in minutes. Thanks a lot for the saved time!
RanaMuhammadRameez
Occasional Explorer
Thanks a lot, Jimmy!
You helped a lot.
I have created this script to load PNGs from a directory to a style file. Hope, It helps someone.
import os
import base64
import sqlite3
import json
# Paths to symbols and new style file
symbol_directory = r"Path\To\PNG\Symbols"
stylx_path = r"Path\To\Styles\symbols.stylx"
# Initialize the .stylx file
if not os.path.exists(stylx_path):
    open(stylx_path, "w").close()  # Create the file if it doesn't exist
print("Connecting Style DB")
# Connect to the .stylx file as a SQLite database
conn = sqlite3.connect(stylx_path, timeout=60)  # Timeout of 10 seconds
cursor = conn.cursor()
print("Connected.")
# Prepare the table for symbols
cursor.execute(
    CREATE TABLE IF NOT EXISTS ITEMS (
        ID INTEGER PRIMARY KEY AUTOINCREMENT,
        CLASS INTEGER,
        CATEGORY TEXT,
        NAME TEXT,
        TAGS TEXT,
        CONTENT TEXT,
        KEY TEXT
print("Table initiated if not existed.")
print("Inserting symbols into db...")
# Insert symbols from directory into .stylx
for file_name in os.listdir(symbol_directory):
    if file_name.endswith(".png"):
        symbol_name = os.path.splitext(file_name)[0]
        image_path = os.path.join(symbol_directory, file_name)
        # Read and encode the image file
        with open(image_path, "rb") as img_file:
            img_data = img_file.read()
            encoded_image = base64.b64encode(img_data).decode("utf-8")
        # Define the symbol JSON structure (simple CIMPictureMarker)
        new_symbol_json = {
            "type": "CIMPointSymbol",
            "symbolLayers": [
                    "type": "CIMPictureMarker",
                    "path": image_path,
                    "title": symbol_name,
                    "url": f"data:image/png;base64,{encoded_image}",
                    "size": 20,
                    "enable": "true",
                    "colorLocked": "true",
                    "anchorPointUnits": "Relative",
                    "dominantSizeAxis3D": "Y",
                    "billboardMode3D": "FaceNearPlane",
                    "invertBackfaceTexture": "true",
                    "scaleX": 1,
                    "textureFilter": "Draft",
        # Generate unique ID and insert into the .stylx file
        new_row = (
            3,  # CLASS (symbol class)
            "",  # CATEGORY
            symbol_name,  # NAME
            "Landmark Symbol",  # TAGS (optional)
            json.dumps(new_symbol_json),  # CONTENT (symbol JSON)
            symbol_name,  # KEY
        cursor.execute(
            # "INSERT INTO ITEMS(ID, CLASS, CATEGORY, NAME, TAGS, CONTENT, KEY) VALUES(?,?,?,?,?,?,?)",
            "INSERT INTO ITEMS(CLASS, CATEGORY, NAME, TAGS, CONTENT, KEY) VALUES(?,?,?,?,?,?)",
            new_row,
        print(f"Inserted symbol: {symbol_name}")
# Commit and close the connection
conn.commit()
conn.close()
print("All symbols have been added to the .stylx file.")
CristianGraf
Thank you! Just what I was looking for!
@RanaMuhammadRameez, @JimmyKnowles, when rolling the code, I see the name and key, but no images or icon?
All my PNG's are 220x200, it's there a size limit?
Thank you!
RanaMuhammadRameez
Occasional Explorer
@CristianGraf Symbol size does no have any restriction. I am unable to test the situation due to inavailbilty of the environment. Have you tried to apply this symbology?
BrennanSmith1
Thanks for this! If anyone is interested, I was able to use this approach to load in the different Wes Anderson color palettes from this R package
import sqlite3
from PIL import ImageColor #to convert hex to rgb
import json
# Connect to stylex file
stylx_file = r"C:\Users\username\AppData\Roaming\Esri\ArcGISPro\Favorites.stylx"
conn = sqlite3.connect(stylx_file)
# define the color ramps to add in
dict_wes = {'wes_BottleRocket1'     : ["#A42820", "#5F5647", "#9B110E", "#3F5151", "#4E2A1E", "#550307", "#0C1707"],
            'wes_BottleRocket2'     : ["#FAD510", "#CB2314", "#273046", "#354823", "#1E1E1E"],
            'wes_Rushmore'          : ["#E1BD6D", "#EABE94", "#0B775E", "#35274A" ,"#F2300F"],
            'wes_Royal1'            : ["#899DA4", "#C93312", "#FAEFD1", "#DC863B"],
            'wes_Royal2'            : ["#9A8822", "#F5CDB4", "#F8AFA8", "#FDDDA0", "#74A089"],
            'wes_Zissou1'           : ["#3B9AB2", "#78B7C5", "#EBCC2A", "#E1AF00", "#F21A00"],
            'wes_Zissou1C'          : ["#3A9AB2", "#6FB2C1", "#91BAB6", "#A5C2A3", "#BDC881", "#DCCB4E", "#E3B710", "#E79805", "#EC7A05", "#EF5703", "#F11B00"],
            'wes_Darjeeling1'       : ["#FF0000", "#00A08A", "#F2AD00", "#F98400", "#5BBCD6"],
            'wes_Darjeeling2'       : ["#ECCBAE", "#046C9A", "#D69C4E", "#ABDDDE", "#000000"],
            'wes_Chevalier1'        : ["#446455", "#FDD262", "#D3DDDC", "#C7B19C"],
            'wes_FantasticFox1'     : ["#DD8D29", "#E2D200", "#46ACC8", "#E58601", "#B40F20"],
            'wes_Moonrise1'         : ["#F3DF6C", "#CEAB07", "#D5D5D3", "#24281A"],
            'wes_Moonrise2'         : ["#798E87", "#C27D38", "#CCC591", "#29211F"],
            'wes_Moonrise3'         : ["#85D4E3", "#F4B5BD", "#9C964A", "#CDC08C", "#FAD77B"],
            'wes_Cavalcanti1'       : ["#D8B70A", "#02401B", "#A2A475", "#81A88D", "#972D15"],
            'wes_GrandBudapest1'    : ["#F1BB7B", "#FD6467", "#5B1A18", "#D67236"],
            'wes_GrandBudapest2'    : ["#E6A0C4", "#C6CDF7", "#D8A499", "#7294D4"],
            'wes_IsleofDogs1'       : ["#9986A5", "#79402E", "#CCBA72", "#0F0D0E", "#D9D0D3", "#8D8680"],
            'wes_IsleofDogs2'       : ["#EAD3BF", "#AA9486", "#B6854D", "#39312F", "#1C1718"],
            'wes_FrenchDispatch'    : ["#90D4CC", "#BD3027", "#B0AFA2", "#7FC0C6", "#9D9C85"],
            'wes_AsteroidCity1'     : ["#0A9F9D", "#CEB175", "#E54E21", "#6C8645", "#C18748"],
            'wes_AsteroidCity2'     : ["#C52E19", "#AC9765", "#54D8B1", "#b67c3b", "#175149", "#AF4E24"],
            'wes_AsteroidCity3'     : ["#FBA72A", "#D3D4D8", "#CB7A5C", "#5785C1"]
# loop through ramps
for cname, cvals in dict_wes.items():
    # initialize json dict for new symbol
    new_symbol_json={ "type":"CIMFixedColorRamp",
                        "colors":[],
                        "arrangement":"Default"
    # loop through colors and populate the json colors dict
    for i, hx in enumerate(cvals):
        rgb = ImageColor.getcolor(hx, "RGB")
        d = {"type": "CIMRGBColor",
            "values":list(rgb+(100,))}
        new_symbol_json["colors"].append(d)
    # insert
    new_row = (2,'',cname,'rgb',json.dumps(new_symbol_json),cname)
    cursor.execute('INSERT INTO ITEMS( CLASS, CATEGORY, NAME, TAGS, CONTENT, KEY) VALUES(?,?,?,?,?,?)', new_row)
# save and close
conn.commit()
conn.close()
Bertrand_Laurancin
Hello,
For information and if it can help other users :
Python script to batch import SVG point symbols into a style file (STYLX)
The following script imports all SVG point symbols from a folder into a style file (STYLX).
import os
import sqlite3
import requests
# Path to the folder containing SVG files
folder_path = r"D:\DEV\Scripts\Python\svgToCimSymbolMyStyle\Symbols"
# Generate Symbol URL
url = "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/Symbols/SymbolServer/generateSymbol"
stylx_path = r"D:\DEV\Scripts\Python\svgToCimSymbolMyStyle\myStyle.stylx"
print("Connected.")
# Loop through all files in the folder
for filename in os.listdir(folder_path):
    if filename.lower().endswith(".svg"):
        svg_path = os.path.join(folder_path, filename)
        print(f"Found SVG: {svg_path}")
        with open(svg_path, "rb") as f:
            files = {
                "svgImage": (filename, f, "image/svg+xml"),
            data = {
                "f": "json"
            resp = requests.post(url, files=files, data=data)
            print("status:", resp.status_code)
            print("body :", resp.content)
            new_row = (
            "",  # CATEGORY
            filename,  # NAME
            "Custom Symbol",  # TAGS (optional)
            resp.content,  # CONTENT (symbol JSON)
            filename,  # KEY
            cursor.execute(
            new_row,
        print(f"Inserted symbol: {filename}")
conn.commit()
conn.close()
The SVG point symbols are located in the following folder:
The script uses the ArcGIS Online or ArcGIS Enterprise REST API (starting with version 11.0) and its generateSymbol operation.
This operation converts a Scalable Vector Graphics (SVG) image into a Cartographic Information Model (CIM) symbol. Source: https://developers.arcgis.com/rest/services-reference/enterprise/generate-symbol/
Example :
You can check that the symbols were correctly imported by copying and renaming the myStyle.stylx file to myStyle.sqlite.
Note: The myStyle.stylx file is simply an SQLite database.
Download DB Browser for SQLite and open the myStyle.sqlite database:
Note: You can see that the symbols have been successfully imported into the ITEMS table.
Note: The value 3 in the CLASS column corresponds to "Point Symbol" in the CLASSES table:
In ArcGIS Pro > Catalog View > Style > Add > Add Style :
Bertrand
Version history
Last update:
‎12-12-2021 03:51 AM
Updated by:
