Assigning an icon from a .stylx file and rotating it, in arcpy
3707
09-06-2018 08:45 AM
ZacharyKlaas
I want to use arcpy to apply a symbol from a .stylx file and then rotate the symbol according to a variable.
Doing this manually, this merely involves clicking on the icon from the gallery pane (where the symbol is located despite being in a .stylx file, the style is clearly regarded as a "project style") and then using "Vary symbology by attribute", "Rotation", selecting the rotation variable, and geographic style for the method of rotation.  It's easy manually, I just want my script to do it automatically.
The relevant code:
   aprx = arcpy.mp.ArcGISProject("CURRENT")
   m = aprx.listMaps("AIS Live Feed")[0]
   l = m.listLayers("xylayer")[0]
   sym = l.symbology
   ##begin code that doesn't work
   sym.renderer.symbol.applySymbolFromGallery("ShipAIS")
   ##end code that doesn't work
It doesn't regard my ShipAIS icon, stored in its .stylx file, as part of my gallery.  I am able to get the icon to change with this code if I select one that is in my default gallery.  Even doing that, though, I don't know how to direct arcpy to rotate an icon once I'm able to access it - there appears to be an "angle" attribute, but I'm not sure how to apply it.
Does anyone know how I might do this?
MarkTurnbull
Hi Zachary
Were you able to resolve this problem. I am encountering exactly the same issue.
Mark
ThomasEmge
You'll need to get down to the CIM level for the rotation piece.
For more detailed information please take a look at Python CIM access—ArcPy | Documentation as well as an excellent presentation from the Dev Summit https://www.youtube.com/watch?v=RkyzeOgCHe4&list=PLaPDDLTCmy4Ys8vfmC7DbX3FHSsyosvh7&index=28
- Thomas
MarkTurnbull
Thanks for responding so quickly Thomas.
My issue is more the python code (applySymbolFromGallery) not recognising symbols in project style files.
ThomasEmge
Are you saying that even with listSymbolsFromGallery(<your_symbol>) you get back an empty list?
I just tried it with Pro 2.6 and it seems to work in my list test case.
and to complete Zachary's code
l.symbology = sym
