Hello - I just upgraded to 11.2 from 11.1 and now my Instant apps configuration page will not display instant app choices. What can I do?
My existing sidebar apps configured at 11.1 will not display the sidebar info panel and I cannot update them. The configuration choice from the app overview page just spins?
Any of you guys have any suggestions:
@MarceloMarques
@JonEmch
@Scott_Tansley
@JakeSkinner
@jcarlson
Thanks-
David
Have you tried using inprivate mode for your browser. Sounds, at first pass, like a caching issue.
I run in Chrome incognito mode so often I never even checked
Here is the dev console from Chrome:
The Chrome console error says it can't find the Instant App Data from here:
webpack://instant-app-landing/src/app/data/AppTypeInfo/AppTypeInfoViewModel.ts
the console log show lots of 'failed to load resource' . . .
In an earlier upgrade, I had added the following to the
\arcgisportal\db\pg_hba.conf file:
*Added a config setting to \arcgisportal\db\pg_hba.conf file:
# TYPE DATABASE USER ADDRESS METHOD
host all all ::1/128 scram-sha-256
I did not add this param to the pg_hba file when going from 11.1 to 11.2
Could that be it?
Unfortunately I can't recall why I added that param in the first place, or when. Feels like maybe I added it going from 10.9.1 to 11.0
Here is something I found for a related Online version of something similar that @KellyHutchins noted
Instant App configure page will not open - Esri Community
but not quite. It's not the Instant App page won't open, its that Portal 11.2 can't find the Instant App data per my Console log screen grab I posted above.
Anyone?
Sorry I've been in meetings all morning and struggling to catch up on project work. Is there any information in the network tab of developer tools, that suggests a resource is not loading or 404, 5xx errors etc. If you use InPrivate mode all the time, then it may not offer the normal value. What happens if you use Edge (or another) using the InPrivate mode?
No problem. If you look at my earlier reply with the dev console image, you will see that the Chrome console error says it can't find the Instant App Data from here:
I have tried in Edge, both in-private and standard, and in Chrome both incognito and standard.
I've got a case in with esri, but yes there are lots of 404s, mostly with Calcite components:
..../apps/instant/node_modules/@esri/calcite-components/dist/calcite/p-f4be18ed.js
So I'm not a developer any more, but I believe a TS file is a TypeScript (JavaScript) file. If so then this has loaded, and it is the TS that is requesting 'the data'. The data will be requested as HTTPS request to the portal (most likely) and that's what we need to see in the Network Trace.
The console view shows what JavaScript function has failed. That will likely have failed because of a failed request to a URL/endpoint and that's what I can't see from screen grabs.
Yeah, the TypeScript is looking for resources that are not there, or did not install in a correct location perhaps. Although I am just getting started with esri support, it appears there are missing js files, nodemodules maybe more in at least 2 locations, instantgallery and sidebar.
When I try to config an existing app, the config template here
https://..../portal/apps/configure-template/app/ui/main/ConfigPanel/ConfigPanelViewModel.js
which is here:
C:\Program Files\ArcGIS\Portal\apps\configure-template\app\ui\main\ConfigPanel\ConfigPanelViewModel.js
can't find other ts, js, and calcite
The install appeared clean and the Event Log only reports some setupmsi application hangs, which I could see anyway when the setup wizard would become unresponsive at the beginning of my install. There are no Carbon Black events, there are some Software Protection Program (SPP) 'start' events.
But I'm totally grasping at straws. It was a bad install, don't know why
Ouch! The only time I saw this level of disaster was when the client was using AWS and GP disk. Quite literally they ran out of iOPs and burst! It took way longer than it should, we knew something was wrong and didn’t even test. We just rolled back the disk images. After upgrading the disk to IO2 (SSD with lots of iops) we got a successful upgrade.
Well, for me the arcgis monitor 2023 logs don't show anything like that. These are new Window Server 2022 VMs with plenty of bandwidth, plenty of disc space, plenty of I/O. There was a small network and storage write blips at install time but that is all.
I mean, other than the Instant Apps Gallery and any Instant app config page, the portal is running great. Server is running great, sans the known webhook launch error, and no issues with data store.
But for us, we are migrating our internal clients from WAB Dev edition to instant apps so this could not have happened at a worse time, sadly.
I performed an upgrade late last year from 11.1 to 11.2 and had issues with the instant apps straight after.
After the upgrade, certain instant apps were no longer available in the instant apps screen. Not only that, if you had existing apps of the ones that were missing, they would no longer work or could be configured, they just ended up with a spinning wheel with a typescript error in the dev console.
The setting that causes this issue is 'enable external content', which is in the portal administrator site under System/Content/External Content.
With this set to true, all the instant apps show and allow configuration. When set to false, the issue occurs. ArcGIS11.1 instant apps work fine with this set to false.
I am not sure if this will assist with your instant app error though.
As for the the missing / moved sidebar, this is a bug (BUG-000163830) that ESRI have fixed in 11.3.
https://community.esri.com/t5/arcgis-instant-apps-questions/slide-in-instant-app-is-not-showing-in-right/td-p/1388978
Thanks for the feedback @RRC_GISServices - interesting. For me, this setting is already set to Enabled: true.
However, when I try to set externalcontent>update Enabled: false, a 500 error is returned. So I don't know if it that is something or not.
And thank you for the info on the sidebar - as I'm sure you'd agree, it is difficult to track every thing we users report . . .
I also have lost my ability to configure or edit existing Instant Apps after upgrading from 10.9.1 to 11.2. I don't have basemap options anymore either. Help!
Hi @ShelbyZelonisRoberson - I can tell you support escalated our case yesterday on this as multiple orgs are affected, so fingers crossed
What was the resolution? We're having the same problem.
None so far @ThomasColson Support wants me to try and remove and then re-add the English language from portal admin with the idea being that upon an 'Add' our missing content may come back. Although it seems straightforward from the help, I don't know what to expect in terms of downtime, interruptions, or behavior.
I work with Tom and they are asking us to do the same thing, but making sure that we have good backups and potentially roll back to 10.9.1. We CAN NOT go there with the time spent upgrading! Our basemaps are also broken, btw. Please let us know how the English language "fix" goes.
Here are the results of my language try:
https://dnsname.scgov.net:7443/arcgis/portaladmin/system/content/languages/remove
Error
"error" : {
"code" : 500,
"message" : "One or more requested language(s) cannot be removed as they are not yet configured, language=en. ",
"details" : null
And from an Add operation
https://dnsname.scgov.net:7443/arcgis/portaladmin/system/content/languages/add
One or more requested language(s) are not supported, language=en.
Code: 500
"message" : "One or more requested language(s) are not supported, language=en. ",
From an Update External Content try:
{"status": "success"} – external content is enabled . . .
I am happy to report that there is a solution to this! In working with support last night we were able to perform certain queries and updates to certain tables contained in the the portal gwdb, all via the postgres command line interface.
The updates will remove and then add languages, and upon completion of the workflow, the English language pack is fully available, thus enabling (for us) the Instant Apps template and config pages, as well as restoring Map Viewer Symbol symbol categories. I cannot speak to a re-gain of the Esri Basemaps content as we did not lose that part first reported here
https://community.esri.com/t5/arcgis-enterprise-portal-questions/basemaps-unavailable-after-upgrading-to-11-2/td-p/1414057/page/2
by @ShelbyZelonisRoberson
I am not able to relay what we did exactly, but anyone affected by this should be able to work with their support analyst now to affect this repair.
Support cannot yet say whether the fix will be included as a patch for 11.2 now or as part of the 11.3 release (or both) - they just don't know yet.
@ThomasColson
FYI the Instant App issue for the Sidebar app does still exist, where the 'Sidebar' has become a "Footer' and the Filter tool is non-functional, and some other css issues, so looking forward to 11.3 for this fix, @KellyHutchins
Wonderful! Thank you for the update @DavidColey ! Hopefully my support analyst can help me get this fixed soon.
Thank you for the information. I will check with our analyst since they have not gotten back to us. I will report if this is a fix for basemaps too, as we lost ours.
Keep me posted as to what they say please! I sent my analyst our portal logs last week, but haven't heard back since. Also have no basemaps (or map viewer symbology options!).
Ok guys - if they need to check with their respective teams, it might help if they had my case number, etc:
Case: 03592799
Analyst: Daniel M.
Me: David Coley, Sarasota County GIS
Same issue with 11.3
