Great work on this Alex, you're input here bailed me out of a tight jam. Thank goodness for SQLiteBrowser.
Hi all,
Thanks for the useful information in this post.
In the current version of Collector (10.3) for Android, the synchronisation failure problem still exists:
when starting synchronisation, the progress bar remains stuck at the very beginning.
So far this happened once after succesfully completing about 10 offline collector projects.
My offline dataset contained about 30 jpegs and still was stuck after a complete night of synchronising on a stable WiFi connection.
I have been able to resolve this by using the following steps:
0- make sure that you make a backup copy of the ArcGIS_Collector on your mobile device to avoid any data loss.
1- locate the folder for the offline webmap which fails to synchronise (ArcGIS_Collector\offline_data\.....)
2- locate the .geodatabase file and copy it to a computer using the usb data connection
3- convert this SQLite database to an XML file with the "Export XML Workspace document" tool in the ArcToolbox
(the can be accomplished by drag and dropping the .geodatabase file in the "Input Data" parameter
4- create a new empty File Geodatabase
5- use the "Import XML Workspace Document" tool to attempt to copy the data.
.. in our case this operation failed with the error " "A row with this OID Already Exists" and a bunch of "Field is not editable." errors.
6- download the sqlite command line tool and connect to the .geodatabase file (SQLite Download Page )
7- this tool will allow you to run SQL queries and inspect your data. I have not been able to find any non-unique values though.
8- assumption: because archiving is used, all records apart from the latest version of feature should be safe to delete. The following SQL statement can be used to remove the older versions.
delete from NAME_OF_YOU_FEATURE_CLASS where gdb_to_date < 5373484;
.. Now you should have exactly one version left of each of your features (which should be the most recent one)
9- Retry from 3) to import the features in your geodatase.. Succes for me at this point!
10- (optional) copy the .geodatabase back to your Android device, so you can perform the synchronisation step and store the offline data in the Feature Service.
As a precaution I deleted any intermediate files from the folder (client_delta, .geodatabase-shm, .geodatabase-wal, and all data inside the "SyncGdbRequest" folder)
These steps helped me, if you decide to use them this is of course at your own risk
@Russel Roberts, it would be appreciated if the Collector team could look into this issue.
Best Regards,
Laurens
Changing IIS settings will only apply if you host your own content on ArcGIS Server Tony, I'm not sure why features would not be syncing if they are hosted.
The data is currently be hosted on ArcGIS Online.
These are the instructions that ESRI provided on changing the uploadreadaheadsize:
Hopefully this helps others!
I contacted ESRI about the issues and they offered to extract and convert the data for me.
I was also told that in 10.3 there will be a tool that will all people to extract the data from collector.
which is nice but the issue should be resolved in collector and we shouldn't have to use a tool to extract it and reload it.
If this is an issue related to syncing back to AGS feature services rather than hosted services I would also like to hear more about the "uploadreadaheadsize" setting in IIS. I have my ArcGIS Sever on IIS and am experiencing the occasional sync failure with offline collections too.
The last time I had this issue the Python script helped (minus the "A row with this OID Already Esists" error requiring esri to step in). However, if this is truly an issue with AGS/IIS setup I'd like to nip this in the bud before I push the use of Collector to a broader scale within my organization. Look fwd to hearing more about your work around Robert.
Hi Robert,
Can you give me some help in changing the uploadreadaheadsize so we are able to sync.
Rod
Dear Robert,
That sounds great!!! Syncing is an issue that needs to be resolved asap. I have enough of staff telling me their data cannot go to the cloud. How can we see this improvement from now on? Will the fix be implemented in the next collector version or this is already set in the sync process?
After working with ESRI support for a couple weeks on this Android not syncing issue, I think we have it solved.
The solution for us was changing the uploadReadAheadSize value in IIS. We previously had a fairly small value, and we bumped it up to our maximum allowable value of 2147483647.
I would also like to know how to solve the problem with "A row with this OID Already Esists" with this python script.
We also have encountered the issue with syncing, we get no error it just doesn't completely sync our edits.
Hello Folks,
I have just encountered the terrible "a row with this OID already exitst" using the python. We are missing very important information for our project. Could anyone help with a working script to solve this issue. I also downloaded the toolbox added by Steve in this forum but I got the same error.
Help please!
Juan
Just an update here. We've managed to solve this issue by removing the duplicate OIDs. The process included copying the raw .geodatabase files off the device and importing them into SQL lite. You can then view the data in tabular form and query/delete the records with duplicate OIDs (ensuring you keep the feature with the latest date.) Following that use the python script or just export to xml workspace > import xml workspace to GDB.
The OID's seem to duplicate as a result of doing an offline feature update. The application stores updates as separate records in a separate file and applies them on sync.
Hi folks,
I thought I'd weigh in. I also have field staff who have experienced the sync issue on an isolated device. I think this has to be related to large amounts of features being collected or editing before a sync. In my case the problem iPad was trying to sync about 118 new points with about 20 attribute fields. Other field collectors had successfully synced with no problem, but with about 1/2 the amount of features being synced. I agree with someone in a related post that this must be tied to timeout issues etc. Hopefully this can be resloved by esri in a later release.
Regardless, I'm happy to report that the python script did work for me with one caveat. In line 8 of the code make sure it reads something like
output_gdb = 'M:\Working_folder\PHL\\NEW.gdb'
The key for me was ensuring that a 2nd "\" is inserted before the file geodatabase name. Other than that one piece of advice this worked seamlessly. Also an FYI I made communication with the ArcGIS Collector Dev. team a few weeks ago with some suggestions and they do plan on having a developed tool (likely in ArcToolbox) to retrieve data from tablets that refuses to sync in the future. Until then this script works great. Thanks Russell Roberts!
Charles Dawley Did you ever sort out why this works on iOS and not Android?
Jeff Shaner Russell Roberts Can you guys provide any insight?
I am having similar issues with syncing errors on Android, but not with iOS.
I can see the map, download it, add a feature, and see it "stored on device."
Then I am getting this error when I try to sync: "An error occurred while synchronizing edits"
Only trying to sync 1 point, with a field 'Number' and a field 'Text'.
Syncs no problem with iPad running ArcGIS Collector (10.2.5)
Have tried syncing with Android 5.0, 4.1.2, 4.2.2. LTE and WiFi. Android Collector Versions 10.2.7 and 10.2.6.
We used to be able to sync without a problem, no idea what the issue is now.
I'm having the same issue when importing the .xml workspace doc. Error 999999 A row with this OID already exists. I'm able to import the schema just fine but the data.
I'd really appreciate any ideas about this, I have a lot of data stuck on a device currently and no way to retrieve it.
Its especially infuriating because I can view the data just fine on the device and the application is working perfectly but I just can't sync any of the edits. I even managed to copy the application and the un-synced edits to a different Android device in the hope it was device related but still no luck.
Hi Michael -
Would you feel comfortable sharing your script? Assigning new object IDs to the XML would help us recover some data. Your help would be greatly appreciated!
Jon
Hi Michael,
Because my sync issues are related to edited data, when I run the script I get the following error:
A row with this OID already exists. Failed to execute (ImportXMLWorkspaceDocument).
I am very interested in your script, because it seems as though it addresses the duplicate OID error I get. Could you share your script with me and elaborate on exporting the geodatabase from the device to XML as well.
Thanks in advance.
Ed
Steve Kocsis, thanks for providing this tool! My hosted service has begun hanging at 1% during sync on a Samsung Tab 3. Oddly, there is no sync errors that I've seen before.
The tool is real simple to use. Just created an empty file gdb and pointed to the <ReplicaID>.geodatabase (not the "client_delta_<Unixtimestamp>.geodatabase").
Hopefully they fix this soon. Until then, this worked for me when running ImportXMLWorkspaceDocument alone did not work.
Hi there,
We encountered a similar issue. We exported the geodatabase from the device to XML and wrote a simple script to assign new objectid's (after tring a dozen other options). The new object id's are incremented to avoid any duplicates. In our case the OID was not of relevance for the data set. Subsequently, the import of the XML succeeded. Just let me know if you're interested in the script.
Hello,
I also wanted to say thank you for the tool. It helped me recover some of the data that was trapped on my Android tablet. Unfortunately some of the data that I collected was in a geodatabase with other files that had their attributes edited rather than collecting new features. When I try to recover this geodatabase I get the same error 999999 A row with this OID already exists.
Will there be any way to recover this data in the future, or is it lost forever?
Many thanks
Faye
Can this be done with an IPad? We are experiencing an issue with syncing some data from an offline data collection effort.
We had an employee download a test site, then deleted about 13 features, created 2 new ones and now we are receiving an error that states
[SYNC ERROR]
A error occurred while synchronizing edits.
Unable to synchronize replica.
The specified attachments could not be edited or does not exist.
Is this because of the deletion of features from the synced data?
We are planning an update for the UC which will address this issue.Here is the python script..watch out for any white spaces that may be generated when copying and pasting..onnce the KB article is released I will point to that support page.First copy the .geodatabase file to your computer. You can get to the .geodatabase file under the ArcGIS_Collector folder > offline data > folder with user account name associated with downloaded data > folder with the webmap id > copy the .geodatabase and you paste it onto your computer. #!/usr/bin/python # Import sys, getopt, arceditor, arcpy modules import sys, getopt, arceditor, arcpy def main(argv): input_gdb = 'Enter .geodatabase location' output_gdb = 'Enter in an existing fgdb location you want data to be exported into' try: opts, args = getopt.getopt(argv,"hi:o:",["ifile=","ofile="]) except getopt.GetoptError: print 'test.py -i <input_gdb> -o <input_gdb>' sys.exit(2) for opt, arg in opts: if opt == '-h': print 'test.py -i <input_gdb> -o <output_gdb>' sys.exit() elif opt in ("-i", "--ifile"): input_gdb = arg elif opt in ("-o", "--ofile"): output_gdb = arg print 'Input gdb is: "', input_gdb print 'Output gdb is: "', output_gdb Temp_xml = "temp.xml" # Delete the xml workspace document if it exists. arcpy.Delete_management(Temp_xml) # Export XML Workspace Document arcpy.ExportXMLWorkspaceDocument_management(input_gdb, Temp_xml, "DATA", "BINARY", "METADATA") # Import XML Workspace Document. This assumes that the outputfile geodatabase is EMPTY. arcpy.ImportXMLWorkspaceDocument_management(output_gdb, Temp_xml, "DATA", "") # Delete the xml workspace document if it exists. arcpy.Delete_management(Temp_xml) if __name__ == "__main__": main(sys.argv[1:]) Russ
The database that isn't coming in has 4 new points. The database that worked had 39 features to sync, lines and points. I ended up with a database with 4 featuresT_1_inserts (line)T_1_updates (line)T_2_inserts (point)T_3_inserts (point)and one table T_1_deletesSome lines were edited from existing linework and some were added in collector. All of the points were added in collector.
Is the above script intended to work for collected features with attachments? If so, have others been able to successfully recover their photos? I'm receiving the error below for the export XML line of code. Any help would be appreciated - ThanksExecuteError: ERROR 999999: Error executing function.Failed to execute (ExportXMLWorkspaceDocument)
Hello,This is the new error I am getting, sorry to be such a pain but I am determined to figure out what I am doing wrong! Thanks so muchRuntime error Traceback (most recent call last): File "<string>", line 40, in <module> File "<string>", line 31, in main File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 1089, in ExportXMLWorkspaceDocument raise e ExecuteError: ERROR 000808: Invalid dataset type
#!/usr/bin/python # Import sys, getopt, arceditor, arcpy modules import sys, getopt, arcpy def main(argv): input_gdb = r'C:\Users\Kyle\Documents\Bioko Island\GIS1\GIS1.geodatabase' output_gdb = r'C:\Users\Kyle\Documents\Bioko Island\APP Data.gdb' try: opts, args = getopt.getopt(argv,"hi:o:",["ifile=","ofile="]) except getopt.GetoptError: print 'test.py -i <input_gdb> -o <input_gdb>' sys.exit(2) for opt, arg in opts: if opt == '-h': print 'test.py -i <input_gdb> -o <output_gdb>' sys.exit() elif opt in ("-i", "--ifile"): input_gdb = arg elif opt in ("-o", "--ofile"): output_gdb = arg print 'Input gdb is: "', input_gdb print 'Output gdb is: "', output_gdb Temp_xml = r"C:\temp.xml" # Delete the xml workspace document if it exists. arcpy.Delete_management(Temp_xml) # Export XML Workspace Document arcpy.ExportXMLWorkspaceDocument_management(input_gdb, Temp_xml, "DATA", "BINARY", "METADATA") # Import XML Workspace Document. This assumes that the outputfile geodatabase is EMPTY. arcpy.ImportXMLWorkspaceDocument_management(output_gdb, Temp_xml, "DATA", "") # Delete the xml workspace document if it exists. arcpy.Delete_management(Temp_xml) if __name__ == "__main__": main(sys.argv[1:])
