Since day one I have basically the same issue as described here: https://community.esri.com/t5/net-maps-sdk-questions/net-maui-map-not-loading-for-the-second-time/m-...
The issue persits on Android (emulator and real device). On Windows it is OK. iOS I cannot test.
See the attached example solution for your convenience (I'm using latest VS v17.6.4).
Please provide a valid license and Apikey in MauiProgram.cs before starting...
The app starts like this:
Then use the lower tab buttons to switch to the "Note" page:
Switching back to the "Map" page shows the watermark, but now map:
If you just move the finger on the "empty" map, it appears again.
I reckon it is a Maui bug...as most of the issues we are having 😞
But I haven't found any workaround yet and my customer gets really annoyed by this bug now as it is in our app since day one and Maui does not seem to improve.
Would be great if you can give me a little insight on this behaviour and maybe let me know a workaround.
Thanks
Soko
