Geodatabase Questions
156
13.8M
1.9K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | Allow the Analyze Datasets tool to update all branch-versioned related system tablesOur organization manages a set of... by SeanLyons New Contributor III 2 0 | 2 | 0 | |
Open | I am preparing branch versioned data in an enterprise geodatabase for publishing to Enterprise Portal. One of the req... by ChristalHigdon_USFS New Contributor III 3 0 | 3 | 0 | |
Under Consideration | In the geodatabase schema report, can a new column be added to list any additional objects (tables, feature classes) ... by JarekDomanski New Contributor II 1 2 | 1 | 2 | |
Open | I often need to create Table Views of linear feature class (FC) attribute tables to either create secondary geometric... by DaveMcPherson New Contributor III 2 0 | 2 | 0 | |
Open | To date it is only possible to store geometries OGC compliant in a File Geodatabase. Accordingly ArcGIS Pro provides ... by Palladius New Contributor II 2 2 | 2 | 2 | |
Open | When you use the Delete field tool on a featureclass in a geopackage it throws a 002557 error.My idea is simply to en... by DuncanHornby MVP Notable Contributor 1 1 | 1 | 1 | |
Open | One feature that we really miss is a backup function that can be triggered by the administrator at any time or on a s... by MarcoGubitzer New Contributor II 5 1 | 5 | 1 | |
Open | ArcPro Versioning Ribbon has a great button: Version Changes. This provides a categorized list of edits in the given... by FredSpataro Occasional Contributor III 9 5 | 9 | 5 | |
In Product Plan | The new Generate Schema Report tool in Pro is a great way to export the details of all objects in a geodatabase. How... by AndrewRudin1 Occasional Contributor II 3 2 | 3 | 2 | |
Open | Regarding the isEmpty ST_GEOMETRY SQL function: ST_IsEmpty returns 1 (Oracle and SQLite) or t (PostgreSQL) if the ST_... by Bud Notable Contributor 0 0 | 0 | 0 | |
Open | ArcGIS Pro 2.6.8, Oracle 18c 10.7.1 EGDB; SDE.ST_GeometryIf I understand correctly, a feature can either have:Null SH... by Bud Notable Contributor 0 4 | 0 | 4 | |
Open | When migrating data from a source feature class to a destination feature class (new or existing), I found an issue if... by GKing New Contributor II 1 2 | 1 | 2 | |
Open | I have been struggling with field unit conversions for many years now. The service data is NEVER in the units you des... by PDodd New Contributor III 6 1 | 6 | 1 | |
Open | Current file attachment functionality is based on a 1:M relationship cardinality (a feature can have multiple attachm... by GKing New Contributor II 1 3 | 1 | 3 | |
Closed | Allow the ability to connect to a HA database in the Add database connection box.HostName=<host1, host2>;Port=<port n... by VaibhavS New Contributor III 0 2 | 0 | 2 |
Idea Submission Guidelines
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
