Geodatabase Questions
156
13.8M
1.9K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Closed | Allow the ability to connect to a HA database in the Add database connection box.HostName=<host1, host2>;Port=<port n... by VaibhavS New Contributor III 0 2 | 0 | 2 | |
Open | Could Esri consider providing a driver for connecting to FGDBs in an SQL client?For example, I can connect to other d... by Bud Notable Contributor 1 1 | 1 | 1 | |
Open | Azure Active Directory options are currently supported only when connecting to an Azure SQL Database or Azure SQL Man... by BKeiser New Contributor II 1 1 | 1 | 1 | |
Open | With version 19c, Oracle offers extended possibilities for database connection strings, as shown in the Easy Client P... by SébastienPerret New Contributor II 3 0 | 3 | 0 | |
Open | Hi everyone, I recently encountered an issue while creating an ArcSDE on a new server, it was throwing me bad login e... by junaidjawaid New Contributor III 1 0 | 1 | 0 | |
Open | It would be really helpful if ArcGIS Pro supported windows authenticated enterprise geodatabase connections for AWS/R... by ChristenWatts New Contributor III 1 0 | 1 | 0 | |
Open | Would be great to have the opportunity to access a feature class' attributes from within other apps...Happy GISing! by Martin_Döllerer New Contributor III 3 1 | 3 | 1 | |
Open | Currently Query Layers only work with .sde connection files. It would be helpful if it would also work with .geodata... by KirkKuykendall1 Occasional Contributor III 5 0 | 5 | 0 | |
Open | when ArcCatalog connects to the enterprise database we have to save the connection file for each database. it could b... by QaisarNadeem1 New Contributor II 1 0 | 1 | 0 | |
Open | With many companies utilizing the cloud, server and system control may come from a third party. As is the case for A... by BrandiKirchhoff New Contributor III 1 0 | 1 | 0 | |
Open | By "Personal ArcSDE" (PSDE), I mean the ArcSDE that runs on SQL Server Express is included for free with ArcGIS Deskt... by AZendel Occasional Contributor III 2 2 | 2 | 2 | |
Open | Currently we are able to create a database connection in ArcCatalog to an SQL Database in Azure, and successfully dis... by LemuelMarquez New Contributor II 10 1 | 10 | 1 | |
Open | It's possible to create a read only connection using ArcCatalog or to simply connect to an availability group listene... by RyanSadler New Contributor III 5 1 | 5 | 1 | |
Closed | Support PostgreSQL/PostGIS connections without a default "public" schema. As of 10.4.1, ArcGIS still is not able to ... by The_Right_Honorable_MatthewSyp New Contributor II 10 2 | 10 | 2 | |
Open | We used to use Query Layers to append into existing ArcSDE Feature Classes but something changed in recent releases a... by RonnieRichards Occasional Contributor III 1 0 | 1 | 0 |
Idea Submission Guidelines
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
