Geodatabase Questions
153
13M
1.9K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Under Consideration | The new Generate Schema Report tool in Pro is a great way to export the details of all objects in a geodatabase. How... by AndrewRudin1 Occasional Contributor II 3 1 | 3 | 1 | |
Under Consideration | Just read this article on Field Descriptions in ArcGIS Online. I think that's a wonderful idea! I went to look up i... by Sarah_of_Lubbock New Contributor III 32 14 | 32 | 14 | |
Under Consideration | To add another use case:Feature class is versioned/archived/branch versioned simply to allow offline use in Collector... by ScottNoldy New Contributor III 35 9 | 35 | 9 | |
Under Consideration | Currently a sync service (used to generate a replica) only allows a single layer per feature class. So you cannot ha... by JoeHershman MVP Regular Contributor 22 5 | 22 | 5 | |
Under Consideration | I'd like to be able to represent the equivilant of a self-join as a relationship class, but since the source and targ... by AJR Occasional Contributor II 12 8 | 12 | 8 | |
Under Consideration | In previous versions ESRI supported Visio or Rational Rose as a CASE tool for Geodatabase modeling. These CASE tools ... by PeterFitts Esri Contributor 31 15 | 31 | 15 | |
Under Consideration | After creating a feature class, it would be convenient to go back after data input, and make changes to the field ord... by NewingtonConnecticut New Contributor II 3460 209 | 3460 | 209 |
Idea Submission Guidelines
User | Count |
4 | |
3 | |
1 | |
1 | |
1 |
