Geodatabase Questions
156
13.8M
1.9K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Under Consideration | In the geodatabase schema report, can a new column be added to list any additional objects (tables, feature classes) ... by JarekDomanski New Contributor II 1 2 | 1 | 2 | |
Open | Registering with geodatabase is an important task in working with geospatial data in different database situations.Wh... by RiccardoKlinger Occasional Contributor 0 0 | 0 | 0 | |
Open | I recently upgraded a version 10.8.1 enterprise SQL Server geodatabase to version 11 using ArcGIS Pro 3.0 Upgrade Geo... by JamiePetersen Occasional Contributor II 6 22 | 6 | 22 | |
Closed | ArcMap 10.8.1, Pro 2.7.2 creates the "sde logfile tables as Oracle Global Temporary Tables GTT when make a selection ... by MMBR New Contributor II 1 2 | 1 | 2 | |
Closed | Add the capability to rename SQL Server Geodatabases. Currently if the SQL Server Database is renamed it breaks the s... by MMBR New Contributor II 4 6 | 4 | 6 | |
Open | Add the capability to rename PostgreSQL Geodatabases. Currently if the PostgreSQL Database is renamed it breaks the s... by MMBR New Contributor II 15 7 | 15 | 7 | |
Open | I would like to be able to change the appearance of the label and reference scale or text size of a dimension feature... by SarahHartholt Occasional Contributor III 6 2 | 6 | 2 | |
Open | Currently, when you use the Add Incrementing ID Field geoprocessing tool to add an OBJECTID field to a non-geodatabas... by MarcoBoeringa MVP Regular Contributor 2 0 | 2 | 0 | |
Needs Clarification | It is very useful to design a "reconcile database" tool, an ability to recognize the changes being made in the data s... by LynnZhang2 New Contributor II 0 3 | 0 | 3 | |
Open | I am a database administrator responsible to setup enterprise geodatabases that store very large datasets (terabytes)... by MarceloMarques Esri Regular Contributor 0 5 | 0 | 5 | |
Open | I am a database administrator responsible to setup enterprise geodatabases that store very large datasets (terabytes)... by MarceloMarques Esri Regular Contributor 0 0 | 0 | 0 | |
Open | There is no way to unregister a SDE layer in an enterprise SDE database. The only option catalog gives me is to dele... by MatthewRyan2 New Contributor III 19 1 | 19 | 1 | |
Open | Our organization has SQL Server Agent jobs which use CmdExec to run SDE commands, such as sdeversion -o compress, for... by ErickJohnson New Contributor II 0 0 | 0 | 0 | |
Open | Currently, the granting of Privileges in SDE is clumsy at best. It could be so much more fluid. 3 boxes. Available... by RayChilcote Occasional Contributor 1 0 | 1 | 0 | |
Open | We all know the drill. You have a feature class in SDE you can't change schema to because a service somewhere is usi... by Anonymous User Not applicable 11 0 | 11 | 0 |
Idea Submission Guidelines
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
