WAB Directions widget shows coordinates instead of address
4696
32
08-02-2017 11:33 AM
JeffPace
WAB in Portal 10.5.1 is still showing coordinates instead of addresses in 10.5.1 (10.5.1 server routing service also) when using a local geocode service
It also displays mixed coordinates, web mercator sometimes, lat/long other times
The actual reversegeocode results for these two points contained a valid address.
{"address":{"Street":"611 13TH AVE E","City":"BRADENTON","ZIP":"34208","Match_addr":"611 13TH AVE E, BRADENTON, 34208"},"location":{"x":-9190285.6009550039,"y":3184609.8380619353,"spatialReference":{"wkid":102100,"latestWkid":3857}}}
The app is publicly facing
ArcGIS Web Application
any ideas?
dlaw-esristaff
JeffPace
Derek LawKelly HutchinsDavid Coley
Confirmed with support this looks like a bug in api.
Esri Case #01970931
JS Bin - Collaborative JavaScript Debugging
Basically if you use "geocoderOptions" with the Directions widget it works as expected.  If you use "searchOptions" in returns coordinates instead of the address when using a local geocoder.
NOTE: Prior to 3.14, this option was named 'geocoderOptions'. this has been deprecated since 3.14 so it has been broken for a long time.  It was supposedly fixed with Defect ID: BUG-000084635 but it looks like not.
Thanks all for looking into it.
DavidColey
Good to know.  Easy enough fix to apply in the api, where would one one change this in the WAB?
RobertScheitlin__GISP
It looks like line 162 of the Directions Widget.js (for  WAB 2.4)
            searchOptions: this.config.searchOptions,
Change to:
            geocoderOptions: this.config.searchOptions,
I have not tested this as I do not see this issue on my end.
DavidColey
Thanks Robert, I too can confirm what Jeff noted earlier for both WAB and API.
JeffPace
Apparently this is a false trail.  geocoderOptions worked because it is deprecated, i.e. the parameter is skipped and it is executing with no options, which means it isnt pointing to the local geocoder.
Currently the issue is you cannot use searchOptions with a local geocoder and have it return an address.
Jianxia
Jeff,
Thanks for boiling down the issue. It is not a jsapi issue. We should add  searchTemplate="${Match_addr}"  to make it come up with human-friendly names for custom geocoder. This will be addressed in the next AGOL release.
Jianxia
DavidColey
I'm sorry Jianxia, but this is an api issue as well.  Will the api team at 3.x provide a directions widget fix at the 3.22 release?
JeffPace
David,
 No fix is needed
var sources =[
// locator: new Locator("https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"),
locator: new Locator("https://www.mymanatee.org/arcgis01/rest/services/tools/AGSParcel/GeocodeServer"),
singleLineFieldName: "SingleLine",
searchTemplate:"${Match_addr}",
localSearchOptions: {
minScale: 300000,
distance: 50000
Works at 3.21
DavidColey
I was missing this, thannks
Looks like you can add line 6 to the Directions Widget.js around line 318 on my end:
          }).then(lang.hitch(this, function(geocodeMeta){
            this.config.searchOptions.sources[0].locator = new Locator(locatorUrl);
            this.config.searchOptions.sources[0].name = geocodeMeta.serviceDescription || '';
            this.config.searchOptions.sources[0].singleLineFieldName =
             geocodeMeta.singleLineAddressField && geocodeMeta.singleLineAddressField.name || '';
            this.config.searchOptions.sources[0].searchTemplate = "${Match_addr}";
            def.resolve();
