webgl framework
16495
06-05-2016 03:49 PM
NickCameron2
New Contributor III
Did you roll your own webgl libraries from scratch or did you base it on an existing framework? If based on a framework, which one?
The context of this question is that I'm looking at adding some custom functionality in an externalRenderer, would prefer to use a framework already in use rather than introduce a new one if possible.
Nick
Tags (1)
JohannesSchmid1
We don't use a full-blown 3rd party WebGL framework, only some smaller utility libraries which should not have an influence on your choice of framework for external renderers.
JohannesSchmid1
NickCameron2
New Contributor III
Ok great - thanks Johannes, have just been using the included gl-matrix library so far, so hopefully can avoid adding another dependency as well.
nicogis
MVP Frequent Contributor
Here you can see some samples https://github.com/nicogis/WebGL
