Hello Team,
We are using ArcGIS javascript API 4.13.
In our project requirement is, ability to dynamically change field and low and high value of the heat map Renderer for the feature layer.
When we change the heat map Renderer (any above settings) then layer is not showing updated view. When we turn 'OFF' and again turn 'ON' the heat map toggle button then it is showing correct view.
Question - When heat map is ON and suppose we change field or Low/High value, then how layer show correct heat map effect on map without layer re-create or toggle heat map (ON/OFF).
We try layer refresh method although its not worked.
